CRX Sunroof....out of Aluminum
Old Aug 13, 2004 | 06:03 AM
CRX T-Si's Avatar
Default CRX Sunroof....out of Aluminum
Has anyone ever made a replacement sunroof for the CRX out of Aluminum??
Anyone ever thought of this before??
When I say sunroof, I mean an actual replacement skin. With that noone has to worry about rust ever and you can polish it or paint it to your liking.
If anyone have time and a welder that wants to do this let me know, I am interested in this.
Old Aug 13, 2004 | 06:29 AM
cleanISEVOCRX's Avatar
Default Re: CRX Sunroof....out of Aluminum (CRX T-Si)
why would you do that , you cant weld aluminum too steel , just make a steel plate and weld that one in , you could pop rivet the aluminum one and seel it with silcone on the inside
Old Aug 13, 2004 | 06:31 AM
CRX T-Si's Avatar
Default Re: CRX Sunroof....out of Aluminum (cleanISEVOCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanISEVOCRX &raquo;</TD></TR><TR><TD CLASS="quote">why would you do that , you cant weld aluminum too steel , just make a steel plate and weld that one in , you could pop rivet the aluminum one and seel it with silcone on the inside </TD></TR></TABLE>
I am not asking to weld the sunroof shut. I was asking for an actual replacement skin.
I seen the CF ones already just would like to know if someone made an Aluminum one.
Please read before you post.
Old Aug 13, 2004 | 06:36 AM
sleep's Avatar
you probly could just cut out the same design and drill the mounting holes if you wanted i guess.. just get a carbon fiber one
Old Aug 16, 2004 | 11:43 PM
L-CON1's Avatar
i made one for a guy back in 97 and i welded tabs to the inner then used allen head screws to mount it. i used foam seal tape on the inner edge to seal it! also it wasent a street car so it didnt have to be water proof.
Old Aug 18, 2004 | 02:06 PM
AMGTortoise's Avatar
Try BONDO j/k
B20_ej1
10
Jul 21, 2007 05:57 PM
Boosted Chemist
Welding / Fabrication
14
Oct 10, 2005 12:41 PM
AIWFCIATR
20
Nov 11, 2004 09:04 AM
FURACERMAN
Oct 4, 2004 05:58 PM
shaddr3
19
Jul 10, 2004 05:53 PM
