are obd0 and obd1 resistor boxes same or different?
Old Aug 13, 2004 | 04:57 AM
mr. Grind's Avatar
Default are obd0 and obd1 resistor boxes same or different?
i have a b18c1 motor in a 1988crx with p/h 550 RC injectors, obd1 dizzy, obd0-obd1 harness and obd1 ecu BUT i have a obd0 resistor box connected to the 550s. Should i be having problems starting the car and keep it running with the obd0 resistor box?
Will i need an obd1 resistor box?
Thanks
Old Aug 13, 2004 | 05:29 AM
crx_88_si's Avatar
stock injectors are p&h right? if so, that'll work fine.
Old Aug 13, 2004 | 05:58 AM
CRX T-Si's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">stock injectors are p&h right? if so, that'll work fine.</TD></TR></TABLE>
This is correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingmarc01 &raquo;</TD></TR><TR><TD CLASS="quote">....Will i need an obd1 resistor box? Thanks</TD></TR></TABLE>
Never seen one before, I don't believe OBD1 cars needed them for the injectors are saturtated.
Old Aug 13, 2004 | 12:56 PM
13sechatch's Avatar
obd1 cars dont have a resistor box they use saturated injectors. you still need peak and hold injectors so you need to use your resistor box still.
Old Aug 13, 2004 | 01:20 PM
4drEF's Avatar
Keyboard Humorist
Default Re: (13sechatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13sechatch &raquo;</TD></TR><TR><TD CLASS="quote">obd1 cars dont have a resistor box they use saturated injectors. you still need peak and hold injectors so you need to use your resistor box still.</TD></TR></TABLE>
for the mos part you are right.
There are some oddball EG's that had a resistor box. I am not sure if they were USDM or what though. Might have been the aniversary ZC EG.
Old Aug 13, 2004 | 02:34 PM
krazie1's Avatar
BANNED
Default Re: (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
Might have been the aniversary ZC EG.</TD></TR></TABLE>
WTF
why???
with that size and weight I think it would move as fast as us 88-91 USDM d15a civic sedans
Anniversary to what??
Old Aug 13, 2004 | 02:46 PM
DieMaster's Avatar
Needs to be About 20% Cooler
what do you mean by peak and hold and saturated?
i'm new to injector types
Old Aug 13, 2004 | 02:51 PM
MENACE's Avatar
Default Re: (JC18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by peak and hold and saturated?
All peak and hold need a resister box to step down the voltage from the ecu. Also all OBD-0 Hondas had P&K
Saturated dont need a resister box, and can handle the voltage from the ECU. They are found on 92 and up. Personally i like saturated better less **** to wire up.
Old Aug 13, 2004 | 02:54 PM
kid-honda's Avatar
The years of the box makes no difference all it is is a resistor hell if you want you can make your own at radio shack or use a DSM one it doesnt matter.
Your problems would be something else.
Old Aug 13, 2004 | 04:08 PM
91civicDXdude's Avatar
92-96 preludes are OBD1 and have a resistor box.
92-93 accords are OBD1 and have a resistor box as well.
Hondamonster
Jul 29, 2007 08:42 PM
russianswty
Oct 17, 2006 01:12 PM
95_red_dc
Jun 17, 2006 08:55 PM
turboZChatch
Sep 29, 2004 10:27 AM
mr. Grind
Aug 15, 2004 12:13 PM
