Advantages of larger rims
Old Aug 13, 2004 | 04:07 AM
Acura EL's Avatar
Default Advantages of larger rims
pls, enlighten me if there are significant advantages of bigger rims (16-17") vs my stock 14" other than just looks.
stock 1991 CRX Si
Old Aug 13, 2004 | 04:11 AM
MENACE's Avatar
Default Re: Advantages of larger rims (red91CRXsi)
I wouldn't go high than 16's. But the Big advantage is Handling. with a larger Rim You Can keep the same overall size tire But have less Sidewall. When you have less sidewall youre car tends to feel Tighter on the road. You have less Sidewall role, thus more Feeling.
Also Its the cool thing to do Thats Reason enuff right there.
Old Aug 13, 2004 | 05:19 AM
Acura EL's Avatar
Default Re: Advantages of larger rims (MENACE)
thanx menace, that was a nice explanation. do you know by any chance was is the bolt pattern on 91 CRX Si and waht tire should I get (16")?
Old Aug 13, 2004 | 05:28 AM
crx_88_si's Avatar
a thinner side wall also means a rougher ride, be prepared.
your bolt pattern is 4x100 and for a 16" wheel you'll want a 205-40r16 tire.
Old Aug 13, 2004 | 05:45 AM
MASTER4666's Avatar
you can fit bigger brakes
Old Aug 13, 2004 | 06:12 AM
streetmodified's Avatar
pros: can look cool, can improve cornering ability, can fit bigger brakes.
cons: bigger rims are usually heavier - so car will feel more sluggish unless you are getting VERY VERY light rims (15 lbs or less), bigger can sometimes look overdone on a small car, bigger costs more for both wheels and tires, if you DONT upgrade your brakes, they will look silly beneath huge wheels (especially a rear drum).
a 15-16 would be good. i think for racing apps (like autocross) ... the biggest anyone ever goes is 15x7. but maybe thats not what you want to do.
EDIT: when i say "the biggest anyone ever goes" - i mean honda guys that actually win national championships. those are the only guys that matter to me
Old Aug 13, 2004 | 07:05 AM
Acura EL's Avatar
Default Re: (streetmodified)
cool ...
I thought it has something to do with speed as well, but bigger brakes is surely a great advantage, cornering is nice, too.
Too bad I just changed the tires and breaks on my 14" stock alloys. On another hand I can keep as spare ...
Old Aug 13, 2004 | 07:48 AM
crxaddikt's Avatar
Default Re: (red91CRXsi)
or just get a nice ZR rated performance tire on your 14"s and i am sure it would handle fine and not be as rough as the bigger ones, but if you want the look of filling the wheel well a little more, i guess the slighlty rougher ride is worth the trade
i think 15's look good and are'nt too big, i am going to get some sometime soon, tired of lookin at my 90si teardrop wheels for 8 years, i need a change
homero
Apr 8, 2012 02:51 PM
tyronne1126
Honda Civic (2006 - 2015)
23
Mar 30, 2009 12:58 AM
stevescivic
Aug 14, 2005 05:54 PM
nsxtasy
Apr 5, 2005 06:15 PM
JDM_Powered
12
Nov 21, 2004 06:44 AM
