zc motor with unfixable error codes?
Old Aug 13, 2004 | 12:32 AM
suprman1124's Avatar
Default zc motor with unfixable error codes?
My ecu throws like 3 codes at me. one's the o2 sensor and the other is the speedo sensor probably due to the fact that my speedo isn't working rihgt now and a 3rd code i cant remember. is it true that ur check engine light is suppose to stay on no matter what u try? thanks for helping
Old Aug 13, 2004 | 12:54 AM
kaoss_11's Avatar
B A N N E D
Default Re: zc motor with unfixable error codes? (suprman)
That is false.
Old Aug 13, 2004 | 05:16 AM
manson's Avatar
Default Re: zc motor with unfixable error codes? (kaoss_11)
replace your o2 then hook up your speedo and then fix the problem with the third code....reset the ECU after you fix each problem to make sure the problem is in fact resolved.
when you fix them your light will go away.... good luck.
the_0ne
Jul 16, 2006 08:01 PM
Koyoloeor
Oct 13, 2005 04:57 PM
vtec-adykt
Sep 12, 2005 01:09 PM
LilManSi
Jan 29, 2004 02:41 PM
