brake swap help
Old Aug 12, 2004 | 11:00 PM
jlsmi2's Avatar
Default brake swap help
I'd like to improve the braking in my 92 b18c1 cx hatch. I haven't had a chance to do much of a search on the topic but i was hoping someone might be able to lay out the correct parts i would need to upgrade to the integra brakes and rear discs ( my car is non abs, and i would assume it is really complicated to add abs, so i'd be happy just with intergra or si brakes). Is gsr necessarily better than ls. Any other honda brakes work well?
How well could I improve my braking with better rotors and pads using the cx brakes? Could it even compare?
Price estimates on parts and labor and any intallation tips would be appreciated as well as specific parts needed.. thanks for suggestions.
Old Aug 13, 2004 | 05:46 AM
JSR's Avatar
JSR
Default Re: brake swap help (jlsmi2)
You can all use the SIR rear disc brakes
Old Aug 14, 2004 | 07:54 AM
jlsmi2's Avatar
what year sir, will 99-00 si brakes work. what about ls, or gsr? any differences in installations, difficulty to install, etc?
Old Aug 14, 2004 | 10:17 AM
JSR's Avatar
JSR
92-95 sir brakes... u can get them off hmo and i believe 94+ integra brakes. Never done it but i dont think its very difficult.
Old Aug 14, 2004 | 12:08 PM
pgpunkguy's Avatar
Default Re: brake swap help (JSR)
i have 94-00 gsr front brakes on my b18c1 eg...
it doesn't matter whether the brakes have abs or not because your car doesn't...
you use stock brake lines...
for the rears, you'll need the ebrake cable from the gsr...
you can also use 92-95 ex/si disc brakes for rear...
for the front you need something w/ a b-series spline for the axles...
97dc2
May 14, 2006 08:23 PM
dude9571
Mar 1, 2006 07:17 PM
stolen4drteg
Dec 20, 2004 04:38 PM
-Whitey-
Dec 20, 2002 01:41 PM
94si94cx
Sep 30, 2002 08:57 PM
