slave cylinder/clutch release fork question
Old Aug 12, 2004 | 10:02 PM
SKDRCR's Avatar
Default slave cylinder/clutch release fork question
ok, I was tearing my motor apart tonight and I have to
disconnect the slave cylinder from the clutch release fork
and there is a round shaped piece of plastic on the fork
on the oppisite side of the slave clyinder. I didn't see anyway
to get this piece off to seperate the two pieces. There
obviously is a way though. Do any of you know the trick
to get that **** off.
TIA, Chris
Old Aug 12, 2004 | 10:14 PM
del_parker's Avatar
Default Re: slave cylinder/clutch release fork question (SKDRCR)
can you take a pic or use http://www.hondaautomotivepart...y.jsp
to show which part you're talking about.
Old Aug 13, 2004 | 03:47 AM
SKDRCR's Avatar
Default Re: slave cylinder/clutch release fork question (del_parker)
i don't have a digital camara but it goes on the small end of number 6
i don't see the exact part though
Old Aug 13, 2004 | 04:14 AM
117's Avatar
117
Never seen anything like that on my 98, or a 92 I swapped a JDM engine into. Of all the Prelude's I've worked on, all of them had solid metal clutch forks, never any plastic pieces in the fork.
Old Aug 13, 2004 | 04:57 AM
SKDRCR's Avatar
Default Re: (117)
Take a look at the slave cylinder on the right,
towards the bottom you will see the clutch release fork.
Well you see that round thing at the end of the fork,
that's what i'm talking about.
Old Aug 13, 2004 | 08:41 AM
sleepy_vtec's Avatar
Default Re: (SKDRCR)
Are you saying that the slave cylinder will not come apart from the fork?
Old Aug 13, 2004 | 08:43 AM
prelittlelude's Avatar
well when you disconnect the slave cylinder the push rod just come s with it, the push rod just sits in that divit, i think im answering your question.. but try not to rip the little booty thing off of the slave cylinder or your gonna get some grease and goo everythwere , and then the little push rod will fall out,
you changed your avatar who is that?
Old Aug 13, 2004 | 08:49 AM
SKDRCR's Avatar
Default Re: slave cylinder/clutch release fork question (prelittlelude)
so do i just pull back on the pushrod part to disconnect it from
the release fork?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">you changed your avatar who is that?</TD></TR></TABLE>
same chick........Gwen Stefani.......B-yoooooou-T
Old Aug 13, 2004 | 08:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">so do i just pull back on the pushrod part to disconnect it from
the release fork?
once you unbolt the slave it all just comes right out, yea just pull back and away.
Old Aug 13, 2004 | 09:16 AM
SKDRCR's Avatar
once you unbolt the slave it all just comes right out, yea just pull back and away.</TD></TR></TABLE>
koo, sounds easy enough
Osbjoey
Apr 14, 2013 08:48 AM
Rikaro
May 11, 2010 05:10 PM
Tripz
Aug 4, 2006 07:52 PM
anewfoundkevin
Apr 20, 2004 03:41 PM
junglistgsr
Dec 7, 2001 09:46 PM
