Clifford alarm problems help me out????
Old Aug 12, 2004 | 09:14 PM
Spence's Avatar
Default Clifford alarm problems help me out????
Ok so it all started with the alarm going off when no one was around the led would blink 5 times when i disarmed the car. 5 times meaning what cause i dont have the manual??? Then now when you arm the car no beep or nothing just lockes the doors and does not arm the alarm. The led light is also staying on constantly wtf is going on with this peice of ****???
Spence
Old Aug 12, 2004 | 10:14 PM
AoiGSR's Avatar
25 Year Member
Default Re: Clifford alarm problems help me out???? (Spence)
http://www.clifford.com/guides/default.asp
hopefully you know what kind of alarm you had.
-aoib0t, who doesn't know if this helps.
Old Aug 12, 2004 | 10:48 PM
Spence's Avatar
Default Re: Clifford alarm problems help me out???? (AoiGSR)
i looked but it does not seem to help me at all but thanks
Old Aug 12, 2004 | 11:40 PM
teamxtant's Avatar
your alarm is most likely in valet mode. It keeps your doors from locking and unlocking but nothing else. What you do is open your drivers door, making sure your dome light turns on. Then turn your key to the ON position but not starting the car. Then on your remote for your alarm, press lock, unlock, lock. If it worked, when you turn your car off, the constant LED will turn off. This is how viper and python alarms work. I can't be certain if it will work with your alarm but since the company who owns viper bought clifford, it might.
Old Aug 12, 2004 | 11:50 PM
Spence's Avatar
thanks man ill try this in the morning
ukdmtony
Audio / Security / Video
Feb 13, 2021 09:38 AM
OOOtony
Mar 27, 2010 08:44 AM
Ej1_coupe
Mar 27, 2005 03:58 PM
93LudeVtec
Jul 9, 2003 10:29 PM
drsues02
May 17, 2002 10:06 PM
