A Question for All Slammed 4th Gens
hell yeah u need camber kits... if u dun wan to buy tires every 3 months of soo.. i suggest you get some right away... i have mine slam 2.25... and i got all 4 camber kit.. if not.. ure steering wheel starts to vibrate.. ure control arms go bad.. ure ball joints break.. and ure cv joint will break like toothpicks..good luck.. cheers
yeah, you gonna need a camber kit. had a friend with a civic had his car dropped 2.5 inches. he insisted that he didnt need a camber kit and that his tires ewrent wearing. bout 3 months later, both front tires blew because they were worn to the steel threads on the inside. you cant see it, unless you jack the car up. i had my car slamme 4 inches, and even with the ingalls, i wa sgetting some tread wear on the insides of the front tires. it is cheaper sepnding 140 for the cambers, than 180 every 3 months
