whats the difference? [guage clusters]
Old Aug 12, 2004 | 08:42 PM
7808's Avatar
Default whats the difference? [guage clusters]
can anyone tell me whats different about these clusters? i got these both today because they had the tach, and mine dont (90 dx hatch)
ones out of a 90 sedan (blue-ish wire on back) and one from a 90 wagon. both 5spds.
one has a box amd a extra light (cruise) and one does not, maybe it fell off when i was removing it?
with both work in my hatch? thanks
Old Aug 12, 2004 | 08:56 PM
EF_LSVtec's Avatar
Default Re: whats the difference? [guage clusters] (fuctup)
it looks like they are the same except for the color and the box that's only connected with a plug...I'd unplug that box and try em both. I have a an 88 gauge cluster here and matched it with the picture on the left (90 wagon)...and they're quite the same too.
Old Aug 12, 2004 | 09:09 PM
crexer's Avatar
Default Re: whats the difference? [guage clusters] (EF_LSVtec)
never seen that little box b4 but tear it off!
Old Aug 12, 2004 | 10:01 PM
onePOINTsix's Avatar
Default Re: whats the difference? [guage clusters] (crexer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">never seen that little box b4 but tear it off! </TD></TR></TABLE>uhh... thats usually needed if the cluster from your car came with it and your swaping clusters, it's usually the VSS signal amp or something to do with cruse control in HFs
Old Aug 12, 2004 | 10:55 PM
Jonathan_ED3's Avatar
Wow, that's a dirty sock
Old Aug 13, 2004 | 12:16 AM
7808's Avatar
Default Re: (Jonathan_EH)
ya im embarred of the sock
the blue wire with the box cluster is out of a 90 civic sedan..
Old Aug 13, 2004 | 12:28 AM
The blue wire and the box are part of the Cruise Control system.
It won't affect anything at all. I've got the same cluster in my car....absolutely perfect.
Don't rip it off whatever you do, it's not going to hurt a dang thing!
Are you sure the Sedan/Wagon clusters are the same as the HB's? Fitment wise, I mean.
I was under the impression that they're slightly different.
Old Aug 13, 2004 | 12:37 AM
7808's Avatar
not 100%, but the look the same to me...
fitment wise, the shape and screw hole locations are itenticle in the 2.
Old Aug 13, 2004 | 03:07 AM
ih8sndq's Avatar
Default Re: (fuctup)
I have two gauge clusters out of a 90 si and a 90 hf and they both have that box, neither one had cruise control. I thought it had to do with the vss.
Old Aug 13, 2004 | 03:23 AM
crx_88_si's Avatar
well you wana know what its for? there's 2 wires that come out and go to a bulb.. what bulb is that for? simple
Old Aug 13, 2004 | 04:35 AM
USDM 4G VTEC's Avatar
they are both the same
as u can see the one on the right is missing the box part
u can still see that the bulb is missing and that the actual plastic legs that hold that box on the cluster are there also
my 90 Civic has it, and all the other 89 Si cluster and 91 clusters i have seen, all have them
just swap the box to whoever cluster u want to use
Old Aug 13, 2004 | 11:05 AM
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">well you wana know what its for? there's 2 wires that come out and go to a bulb.. what bulb is that for? simple </TD></TR></TABLE>
For cruise control...that's what the blue female plug on the box is for.
Old Aug 13, 2004 | 11:19 AM
4drEF's Avatar
Keyboard Humorist
90 Sedan with a 5 speed?
Go back to that junk yard and see if it has a D16A6 then grab the front knuckles!
I think you found an EX sedan!
Unless they made an LX with a 5 speed... I don't think they did though.
Old Aug 13, 2004 | 11:47 AM
Default Re: whats the difference? [guage clusters] (4drEF)
LX 5 speeds are very common. The tachs have the same indicated redline as the EX/Si cars.
That's all I ever see in the junkyard [LX 5 speeds]
Old Aug 13, 2004 | 01:23 PM
7808's Avatar
well they both work great. damn its nice havin a tach again! anyone want the other? check my sig.
Old Aug 13, 2004 | 03:31 PM
B2FiNiTY's Avatar
How did that sock get so gross?
Old Aug 13, 2004 | 03:44 PM
BiG Chris's Avatar
Default Re: whats the difference? [guage clusters] (B2FiNiTY)
while on the topic what is the true differnce with the cluster from the 88-89 to the 90-91 because i want to put in a differnt one but its made for the 90-91...
Old Aug 13, 2004 | 04:46 PM
illestrolla247's Avatar
Default Re: whats the difference? [guage clusters] (BiG Chris)
i swapped clusters in my EF and my old one had the box and my new one doesnt i just left the blue clip out and it works fine
also the box isnt for vss the vehicle speed sensor is the thick black wire that plugs directly into the back of the speedo
Old Aug 13, 2004 | 08:01 PM
91civicDXdude's Avatar
my DX hatchback didnt come with cruise control, AC, or any option that i can think of (besides tilt wheel), but the factory cluster had that box. I also have the plug that goes in it.
90 civic hb
Oct 8, 2007 10:08 AM
ntb
Mar 30, 2006 08:20 PM
tsheej
Dec 30, 2004 12:55 PM
ace4nwk
Audio / Security / Video
Jan 12, 2004 02:49 PM
HatchBox
Aug 7, 2002 02:16 AM
