b18a1 motor into crx
Old Aug 12, 2004 | 08:28 PM
ramennoodles's Avatar
Default b18a1 motor into crx
put a ls motor into a crx, using pr4 ecu, stock wire harness, stock distributor and injectors from single cam motor. car sounds like its misfiring. plugs had lots of carbon. could this be from the distributor or the injectors? we didn't have any injectors or distributor with the b18a so we just put the ones from the old motor on. do I need to buy a new distributor or injectors? or maybe both?
Old Aug 12, 2004 | 08:39 PM
Newman's Avatar
New User
Default Re: b18a1 motor into crx (600gixxer)
What model is the CRX? I hope it's a (or converted to) MPFI. Also, you can't use the CRX distributor or your timing will be way off.... use the LS distributor. Also, depending on your CRX model, might have to swap the crank sensor wires.
Old Aug 12, 2004 | 08:47 PM
Default Re: b18a1 motor into crx (Newman)
its a 91 hf. so are the injectors ok?
Old Aug 13, 2004 | 01:08 PM
egchan's Avatar
injectors are fine , its the distributor.
Old Sep 2, 2004 | 01:49 PM
legacytunes's Avatar
Default Re: b18a1 motor into crx (SlickCRX)
i have a 89 si . will the b18a distributer plug rite in the crx harness without any rewireing. thanks
Dee A Nine
Jan 23, 2012 07:35 PM
Chiclana
Jul 29, 2002 10:47 PM
Mazmay
11
Oct 28, 2001 08:09 PM
