Turbo y8 question...
where should i run my primary o2 sensor? in the HF mani?...or in the o2 housing for my DSM turbo, or should i just plug both of them up and put a bung in the DP near the cat?.
also...does anyone know of what i can use to plug up the hole in the mani, and o2 housing, or should i just weld them shut..haha
thanks a lot!!!
thanks a lot!!!
just get some bolts and grind them down , wrench them in and your done.......then get an o2 bung and weld it to your dp , screw your o2 sensor in and your done with that too.
