H22a swap wireing ?
Old Aug 12, 2004 | 04:59 PM
cherns's Avatar
Default H22a swap wireing ?
Ok i have a f22, which i am swapping for the h22a, The Ecu came with the engine, my question is, should i get and USDM h22a1 and plug it into the ECU , then wiring from the engine to it ( knock sensor, EGK(sp)..ect ) the harbess? Or is there some other way to do it? thanks
Old Aug 12, 2004 | 05:13 PM
H22CL's Avatar
you say the ecu "came" with the engine, sounds like the got the engine already. then you say "get and USDM H22A1". do you have the motor already? Is the ecu you have a p13?
Old Aug 12, 2004 | 05:37 PM
Quick99Si's Avatar
Default Re: H22a swap wireing ? (cherns)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherns &raquo;</TD></TR><TR><TD CLASS="quote">Ok i have a f22, which i am swapping for the h22a, The Ecu came with the engine, my question is, should i get and USDM h22a1 and plug it into the ECU , then wiring from the engine to it ( knock sensor, EGK(sp)..ect ) the harbess? Or is there some other way to do it? thanks</TD></TR></TABLE>
Looks like you made that post with your left foot while undergoing brain surgery. Try to clean it up a bit to let us normals understand it, eh?
Adi
asmallsol
Oct 2, 2023 07:13 PM
Ty.jon
Oct 8, 2018 08:20 PM
gorthjr
May 30, 2010 04:00 PM
snake679
May 15, 2003 04:27 AM
