F20 vs. h22??
Old Nov 30, 2001 | 03:40 PM
paul9luap's Avatar
Default F20 vs. h22??
Hey, I've been researching the H22 for awhile, and I thought I was set on getting
one, UNTIL, several days ago, I ran into some inforomation about the JDM SiR
Accord, running the F20. I've got the 2.2L SOHC non-VTEC and a 5-speed in my '97 Accord.
Will the F20 fit in my accord and match to my tranny, axils, etc.. or is not worth it
and get the bigger h22, that has got more aftermarket parts and service for it?
Peace.
[Modified by paul9luap, 12:41 AM 12/1/2001]
Old Nov 30, 2001 | 05:16 PM
SOHCArchangel's Avatar
Default Re: F20 vs. h22?? (paul9luap)
just do an h22 swap, f20b rotates clockwise not counter clockwise
Old Nov 30, 2001 | 05:40 PM
Conechaser's Avatar
Default Re: F20 vs. h22?? (SOHCkordVTEC)
I thought the S2k was the only car that had an engine that rotated 'backwards'?
Old Nov 30, 2001 | 07:25 PM
JinMTVT's Avatar
New User
Default Re: F20 vs. h22?? (94Accord)
Accord SIR have F20Bx wich rotates the same way as H22. .
it is a 2.0l DOHC vtec that is between 160 and 200PS at 7200rpm ..
SIR are only automatics..SIR-T are manuals (96-97)
better rod/stroke ratio ..but less torque than the H22a
the only problem is that lack of support from all manuf..though Mugen had done research on that enigne ( accord 96-97 SIR SIR-t F20B2 )but they never released anything for it ( knowing that honda was working on the new engines that we see now .. Ivtec 2.0 l that can easily go up to 240 HP if tunned properly )
one of the problem for that swap is the lack of power steering pump braket and holes to bolt it..
even though an h22a braket could be fit..
cause al the SIR-SIR-T accord in JDM land have electric power steering.wich is only avaible in RH drive unfortunatly ( or i would already have it in my lude ahha )
neway..just search for a good H22 wich is cheaper, has more supoprt from the industry and power steering brackets
ehhe
Old Dec 1, 2001 | 02:23 AM
Big James's Avatar
New User
Default Re: F20 vs. h22?? (JinMTVT)
Just here to echo the statements of the above gentleman. He is absolutely correct. The F20B is an excellent motor, but here in America it just does not have the peotential that the H22 has. You will spend a lot more money, and have less power. To make light of the domestic arguement over imports, their is no replacement for displacement.
Old Dec 1, 2001 | 11:40 AM
paul9luap's Avatar
Thanks guys. Lots of help!
Old Dec 1, 2001 | 12:01 PM
ehhe
HO DONG mai quebecois compatriot
the SIR-T had the f20b
and the SIR had the H22
and you could get the SIR-T in auto
can someone clarify angular directional rotation of the F20b
we all know the F20C which way it goes
methinks honda had all f-series DOHC's rotate clockwise
all others counterclockwise
Old Dec 1, 2001 | 12:17 PM
Nick M's Avatar
The F20b is essentially an H22 with less displacement, it does not spin a 'different' way than the H22. Interesting note Apexi's drag integra has an H22 that spins in the opposite direction than the factory H22 does, i do not remember the benefit of making it spin in the opposite way.
The f20c is totally different than the f20b apparently. EX: you cant put F20c cams into an F20b head in the same way you cant put f20c cams into an H22, but u can put f20b cams into a H22, there is no benefit, but they have the same cylinder head.
Old Dec 1, 2001 | 12:35 PM
Default Re: F20 vs. h22?? (Hondasport94)
oO?
Old Dec 1, 2001 | 02:27 PM
Nick M's Avatar
Oo?
Old Dec 1, 2001 | 04:23 PM
Old Dec 1, 2001 | 05:49 PM
John's Avatar
New User
Oo?
translation anyone?
Old Dec 2, 2001 | 01:16 AM
Big James's Avatar
New User
Actually, the SiR and the SiR-T both came with the F20 motors. The only Accord that the H22 is available in is the Euro R/Type R model. This is according to an Accord brocure that was sent to me from someone who works for Honda in Japan. As for the auto, yes you could get them like you said. As a matter of fact, that is the tranny that is in my car.
[Modified by Big James, 5:16 AM 12/2/2001]
scrubdakiller80
Sep 21, 2016 09:20 PM
benzcivic99
Apr 16, 2002 04:45 AM
Accord15
Jan 12, 2002 10:29 AM
