Knock sensor removal and replacement?? what size socket is it.. and how should i attempt to put it
Old Aug 12, 2004 | 12:38 PM
birds_sol_94's Avatar
Default Knock sensor removal and replacement?? what size socket is it.. and how should i attempt to put it
just what the title says... knock sensor removal and install... what to use and how to!?
Old Aug 12, 2004 | 12:46 PM
k_spek's Avatar
Default Re: Knock sensor removal and replacement?? what size socket is it.. and how should i attempt to put
I believe you need a deep socket 27mm. The knock sensor is just like a bolt. You just unthread it off and then thread the new one in. I'm not to sure of the torque specs of it though. I hope that helps.
Old Sep 7, 2004 | 09:52 AM
BdoubleU's Avatar
Mine (b16a 1st gen) was a 27mm deep socket, however the s2000 one that I tried to replace it with was smaller.
No specific torque spec just hand tight.
2pac1
Jul 3, 2019 03:56 PM
Excelerate
Nov 15, 2003 12:01 AM
DubbleD
May 29, 2003 12:12 PM
rjardy
May 23, 2003 01:27 AM
