Cam gear install & Timming belt/waterpump install
Old Nov 30, 2001 | 03:38 PM
GSR -97's Avatar
New User
Default Cam gear install & Timming belt/waterpump install
I've got a set of cam gears for my car to and I've heard It's a hard install and is almost like doing a timming belt change...
Is this true? My timming belt may need a change in the next year. Should I do the timming belt/water pump, and cam gears all at once to save time/money?
If I'm willing to spend the time, would this be a job I could do myself and what tools would I need?
Any advice please!
Old Nov 30, 2001 | 04:14 PM
C-speed's Avatar
Default Re: Cam gear install & Timming belt/waterpump install (GSR -97)
Merry xmas:
http://www.c-speedracing.com/howto.html
Old Dec 1, 2001 | 08:52 AM
owen_the_soyboy's Avatar
installing ONLY cam gears is a very very simple procedure.
installing cams makes the process a lot harder / time consuming / ned to know what yer doing.
timing belt change is easy, but getting the crank pulley bolt off (at least getting it loose) is the hardest part.
HTH!
masospaghetti
Jun 26, 2016 05:45 AM
boomersz
Feb 24, 2007 08:19 PM
skata89
Dec 19, 2006 09:03 AM
ImportechPerformance
Apr 2, 2006 02:38 PM
acatak
Jan 12, 2003 05:30 PM
