sohc zc on d16. HELP.
Old Aug 12, 2004 | 12:12 PM
GreenMachineRex's Avatar
Default sohc zc on d16. HELP.
ok well my buddy has a sohc zc ehad he is going to give me and i had some questions...
1. will it bolt up to my block? stock 91 si crx motor. d16a6.
2. what intake mani do i use. the sohc zc or the d16a6.
3. and it has a problem. when the #1 pistion is up. the vavles don't close all the way...what colud be wrong with that.??
4. with d16a6 injectors fit?
thanks!
Old Aug 12, 2004 | 01:49 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: sohc zc on d16. HELP. (GreenMachineRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenMachineRex &raquo;</TD></TR><TR><TD CLASS="quote">
thanks!</TD></TR></TABLE>
Is it at TDC on the compression stroke or the exhaust stroke? I'd bet money that you're looking at it at TDC on the exhaust stroke, which is just after the intake valves start to open and just before the exhaust valves fully close. All four valves should be slightly open then.
Old Aug 12, 2004 | 04:17 PM
Default Re: sohc zc on d16. HELP. (tjbizzo)
bump
the king.
Sep 26, 2006 12:32 PM
farmboy777
12
Jan 19, 2006 08:26 AM
mikikanazawa
Aug 14, 2003 09:08 PM
Disco Stu
Jan 14, 2003 12:22 AM
Ef Whore
Jan 2, 2003 05:36 PM
