Car wont start/dies out of the blue?!
Old Aug 12, 2004 | 11:56 AM
BlueFang08's Avatar
Default Car wont start/dies out of the blue?!
So today I went out to start my car and it started up just fine. So I go to put on my seat belt and my car just dies. I crank it a few more times then it starts. I start driving i get half a block down and then it just dies again. This time for good.
I checked my volt meter and when the car is off its at 12.8. So its not the battery. And i can hear the starter going when i try and crank over the car.
Anyone have any ideas? Fuel pump/ fuel filter? Alternator?
Old Aug 12, 2004 | 11:58 AM
Filthy Focker!'s Avatar
Default Re: Car wont start/dies out of the blue?! (BlueFang08)
Could be a bunch of things. First what year is it?
fs
Old Aug 12, 2004 | 12:00 PM
BlueFang08's Avatar
Default Re: Car wont start/dies out of the blue?! (filthy_shovel)
Its a 97 accord ex with 125,000 miles on it.
Old Aug 12, 2004 | 12:10 PM
No start situations are always the same. You need to look at a bunch of things systematically.
1. got fuel?
is the tank empty
turn the ignition to on and listen if your fuel pump is buzzing. Have a friend stick his ear near the gas fill hole.
get under the hood, and after cranking it for a bit, smell for gas.
You may also disconnect the fuel line going to the fuel rail and crank. Check if gas is reaching it.
2. If this checks out, take a sprak plug out stick it in the plug wire, hold it to the block and crank. Look for spark at the spark plug.
3. Now if this checks out, then you need to look at a couple of sensors and such.
Can you check what i wrote in point 1 and 2 first?
fs
Old Aug 12, 2004 | 12:11 PM
motormanSR's Avatar
dude that could be a bunch of things...your miles are not too high sdo you should be good. got gas?
is you engine turning over??
did you check you oil level or leaks?
might be the starter...
Old Aug 12, 2004 | 12:15 PM
Default Re: Car wont start/dies out of the blue?! (motormanSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormanSR &raquo;</TD></TR><TR><TD CLASS="quote">
might be the starter...</TD></TR></TABLE>
Oil levels or leaks have nothing to do with it...
If the car cranks, then starter is fine...
DO what i wrote in my previous post and come back here if it does not check out right.
fs
Old Aug 12, 2004 | 12:47 PM
earthworm's Avatar
Providing you have at least 12.2 v (I think that is the threshold number) at the battery, you are good . The alternator should add another volt or two to that figure, this is EZ enough to check. (13.5 to 14.5 roughly)
I surely hope you do not have 125K miles on the fuel filter(s) - unless you are going for a record !
A gage should be used to measure the pump output, but I do not know what the serviceable number is.
We have 145K on our '97 Accord - the same may well happen to us.
Old Aug 12, 2004 | 01:25 PM
BlueFang08's Avatar
Default Re: Car wont start/dies out of the blue?! (earthworm)
I had a friend crank the motor over while I listend for the fuel pump and didn't hear any clicking at all. I even put my ear right above the fuel pump in the trunk and listend in and nothing.
We cranked it for awhile and didn't smell any fuel under the hood.
I am not sure when the filter was replaced last. I am the 2nd owner and got the car at 60k.
I am pretty sure i need a few filter but do i also need a new pump.
(i cant find my tools to check the spark plugs but the dizzy, plugs, wires were all replaced about 20k ago. The wires were a little longer with about 40k ago.
Old Aug 12, 2004 | 01:30 PM
Ok, now if you can't hear the pump, you can stop there for now. DOn't need to check for spark or anything like that.
DO you have a multimeter?
Get to the fuel pump connector.
Put your multimeter (if you don't have one, you can use a test light) and probe the signal wire and the ground.
Turn your ignition on, and see if you have voltage. If you have voltage, you need a new fuel pump.
If no voltage, then you need to check the main relay (feel it click) or your wires going to the pump for broken wires and such,
fs
Old Aug 12, 2004 | 04:10 PM
motormanSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">
fs</TD></TR></TABLE>
i usually like to start with the simple things...i have found this to work. i said to check the oil levels simply because it's possiple to spin a bearing if all the oil leaks out....if this happens you will the hear a vrroom sound from the starter but the engine will not turn..it's just a simple thing thats all.....
i said it might be the starter because there is a coil inside the starter that can be damaged...the resistance of the coil can be affected causing the efficienct of the starter to be decreased....thus not enough power is provided to turn the crank as many time as it needs to start
mr. shovel... i was merely presenting my opinion..no disrespect intended but look deeper into ideas before you trash them
p.s. you suggestions were good ones as well
Old Aug 12, 2004 | 04:36 PM
BlueFang08's Avatar
My oil level is right at the mark (full). And I have not noticed any oil spills.
Old Aug 12, 2004 | 06:25 PM
BlueFang08's Avatar
Fixed!
Old Aug 12, 2004 | 06:40 PM
Puddles's Avatar
Same thing happened to me today about an hour later...wierd. But I was driving on the Intersate and my car just died as if it ran out of gas. I just put gas in so I'm guessing that it's the fuel pump or something along those lines like BlueFang's. So blue, what did you do to fix it. I hear a little noise from my Fuel Pump when the car is turned into on, but my engine just rotates and no actual start. I'm going to get a filter and try that, but I'd want to know if before I make the trip down to where my car stopped, about 25 miles away, should I get the Pump and be ready to use it. Cause I figure if I can hear the pump just a little, then it's working but the filter isn't giving enough gas to it so it's really quiet.
Thx
Puddles
Old Aug 12, 2004 | 06:47 PM
bodiez's Avatar
Hit the floor!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueFang08 &raquo;</TD></TR><TR><TD CLASS="quote">Fixed!</TD></TR></TABLE>
Wat was it?
Old Aug 12, 2004 | 06:56 PM
The_Todd's Avatar
Farts in the shower
donkey...it was because your engine bay was so dirty
So what was it??
Old Aug 12, 2004 | 07:01 PM
-RedneckDave-'s Avatar
Working
What was it
Old Aug 12, 2004 | 09:17 PM
BlueFang08's Avatar
Default Re: Car wont start/dies out of the blue?! (-RedneckDave-)
I was the relay, went and got a new one and works just fine now. I wasn't getting any power when I tried to start my car.
Old Aug 13, 2004 | 02:00 AM
Puddles's Avatar
Holy...! So it could also be my relay. Oh that's too cool. *sarcasm*! So what do you guys still think of mine? It's getting power, cause I can hear it but it's really quiet where it used to be loud.
Thx
Puddles
ninjaturtleEG
Sep 14, 2016 11:15 AM
biggs88
Sep 23, 2012 01:31 AM
92jdmxsiteg
May 26, 2007 04:24 PM
BlueLude84
Jan 13, 2007 10:11 PM
inane
10
Nov 2, 2004 11:15 PM
