DC sports H22 Header...
i need a header like 2 weeks ago and summit racing has the dc sports ceramic 4-2-1 header... anyone have any expierence with these? its for an JDM h22a swap... and i live like 15 mins from summit so i can just pic it up easy
pic of said header...
http://store.summitracing.com/...c5009
thanks
thanks
Your search for dc sports h22 header returned no results.
Please try different search criteria or a different data set.
Your search for h22 dc sports header returned no results.
thanks but i tried that already
for 300.00 dollars i wouldn't spend the money. They can easily be found used for half the price
The dc gained 4 whp and 2 ft/lbs of tq over the stock header on my car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan »</TD></TR><TR><TD CLASS="quote">for 300.00 dollars i wouldn't spend the money. They can easily be found used for half the price
The dc gained 4 whp and 2 ft/lbs of tq over the stock header on my car.</TD></TR></TABLE>
werd, i would deffinately get a used one
Does anyone know the specs of the DC Sports Header?
Primary Diameter
Secondary Diameter
Collector Size
I believe the collector size is 2.0". Just wanted to verify.
Primary Diameter
Secondary Diameter
Collector Size
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal »</TD></TR><TR><TD CLASS="quote">It would depend which one had the bigger primaries... Anyone can chime in with the diameters?</TD></TR></TABLE>
That's what I'm looking for, because there are some exhaust calculators out there that determine that's optimial for primaries, how long it should be, optimal diameter for secondaries, how long that should be, as well as collector size depending on engine parameters and camshafts. I want to play around with it.
just mod the collector to 2.5" and there you go a cheap and affordable header.
I did it to my DC header and i noticed significant gains on t he butt dyno. It definitely pulled alot harder when i modded the collector.
I will post the before and after dynos with this header.
Just get a used DC header. I got mine for $50 off a friend.
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago »</TD></TR><TR><TD CLASS="quote">I installed one of these at work. Not sure on exact mesurments but the DC is smaller then the stock. Just a wast of money.</TD></TR></TABLE>
So its a waste of money because of how they looked to you?
See the 5th post for dyno proven results.
hey
i got dc headers used too
got em for like 65$
hrm, im currently
running
2.25" piping with a high flow cat
if i open up my collector to 2.5, or should i go 2.25?
thx
running a 99 base prelude
got em for like 65$
hrm, im currently
running
thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foshizllmynizl »</TD></TR><TR><TD CLASS="quote">so no one really answered my question ... which is better to mod. a DC or a Weapon R ... btw weapon R on ebay is really cheap ....</TD></TR></TABLE>
The weapon r made 2 whp and 2 ft lbs of tq over the stock header.
The DC made 4 whp and 2 ft lbs of tq over the stock header.
*Both run open header*
https://honda-tech.com/zero...age=5
Get a used one.
I had a CC 4-2-1 on my lude and it def. helped the mid range/top end.
The only thing I didn't like about it was the oxidation after a year or two.
crazyvtec93h22
Mar 4, 2006 05:37 PM
cpforyou
Jun 29, 2005 03:18 PM
