new auto tensioner kit
Old Aug 12, 2004 | 11:31 AM
iwhichisme's Avatar
Default new auto tensioner kit
Just wandering if any one has any experience with the newer improved auto tensioner kit from honda. The part number is 06144-P13-305. Im assuming it would be better off then the original ones, which are known to fail. Just need some clarification. Also when replacing the belt on an h22a. is there a tensioner pulley that needs to be replaced also besides the timing belt, and auto-tensioner? Or is it just those 2.
peace,
Old Aug 12, 2004 | 12:51 PM
SuperSlow's Avatar
Default Re: new auto tensioner kit (iwhichisme)
I have it on mine. Do a search.
Old Aug 12, 2004 | 02:38 PM
iwhichisme's Avatar
Default Re: new auto tensioner kit (SuperSlow)
how long have you had it on yours? already done a search.
Old Aug 12, 2004 | 03:14 PM
satan_srv's Avatar
I would recommend going with an H23 manual tensioner assembly.
otherwise the kit is the t-belt and the autotensioner itself..I don't think it would include the pulley. you should also be doing your water pump
Old Aug 12, 2004 | 04:45 PM
iwhichisme's Avatar
Default Re: new auto tensioner kit (satan_srv)
yeah ive heard of a lot of peeps going to the manual tensioner. But from what i understand; The kit comes with an auto-tensioner that was suppossed to be an improvement. I did intend on changing the water pump as well as the pulley also. Yeah i know the kit doesnt include the pulley, just found that out like a sec ago. thanx for the help guys
Old Aug 12, 2004 | 04:52 PM
PreludeRacer023's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">I would recommend going with an H23 manual tensioner assembly.
otherwise the kit is the t-belt and the autotensioner itself..I don't think it would include the pulley. you should also be doing your water pump</TD></TR></TABLE>
agreed
Old Aug 12, 2004 | 05:02 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme &raquo;</TD></TR><TR><TD CLASS="quote">how long have you had it on yours? already done a search.</TD></TR></TABLE>
17k miles with the new auto-tensioner. But 164k before that with no probs. However, my setup is stock now. I will not be trusting the auto after changing head/cams.
Old Aug 12, 2004 | 05:39 PM
Quick99Si's Avatar
What are the symptoms of an out-of-spec timing belt tension?
Adi
Old Aug 12, 2004 | 05:54 PM
SuperSlow's Avatar
Default Re: new auto tensioner kit (Quick99Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick99Si &raquo;</TD></TR><TR><TD CLASS="quote">What are the symptoms of an out-of-spec timing belt tension?
Adi</TD></TR></TABLE>
tension? Slapping.
Old Aug 12, 2004 | 06:34 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme &raquo;</TD></TR><TR><TD CLASS="quote">yeah ive heard of a lot of peeps going to the manual tensioner. But from what i understand; The kit comes with an auto-tensioner that was suppossed to be an improvement. I did intend on changing the water pump as well as the pulley also. Yeah i know the kit doesnt include the pulley, just found that out like a sec ago. thanx for the help guys</TD></TR></TABLE>
if you're stock sure I guess....but how many times must it fail before you switch? It's slightly more expensive I think I haven't looked up prices lately but I got mine off an old h23 for $40...peace of mind
Old Aug 13, 2004 | 04:40 PM
iwhichisme's Avatar
yeah i here ya, my plan was to go with the manual setup, but a freind of mines got the the auto tensioner/ timing belt kit for pretty much nothing. so i figured id give it a try. If it fails, "manual here i come!!"
Old Aug 13, 2004 | 05:10 PM
BioXide02's Avatar
How often do you have to adjust the manual one?
Old Aug 13, 2004 | 08:16 PM
satan_srv's Avatar
Default Re: new auto tensioner kit (BioXide02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BioXide02 &raquo;</TD></TR><TR><TD CLASS="quote">How often do you have to adjust the manual one? </TD></TR></TABLE>
I was running a power enterprise super strong belt..so never
Old Aug 13, 2004 | 08:28 PM
BioXide02's Avatar
I was running a power enterprise super strong belt..so never</TD></TR></TABLE>
Okay, well lets say if you where running an OEM belt?
fall50
Mar 29, 2015 07:42 AM
ZXRider
Nov 1, 2006 08:22 AM
BB6-213
Jun 16, 2005 08:37 PM
patastinky
Mar 16, 2005 12:41 PM
enikdawg
Jun 26, 2003 06:13 AM
