dust cap?????
Old Aug 12, 2004 | 11:30 AM
jdmrex91's Avatar
Default dust cap?????
This weekend I changed the clutch in my project 91da I just picked up. I have never changed a clutch by myself before, and when all back together I cant put it into gear while the car is running but I can while its off.
I had a friend thats a mechanic come over and look at it once I had taken everything back apart and he told me that I crushed the dust cap and that the clutch pressure plate I had was no good.
My question is, the dust cap is the little thin plate on the bottom of the tranni? and I used a pressure plate from a 92 b18a is that the reason that the clutch pressure plate is no good?
any information will be greatly appreciated!
Old Aug 12, 2004 | 11:33 AM
jdmrex91's Avatar
Default Re: dust cap????? (jdmrex91)
ttt
Old Aug 12, 2004 | 11:55 AM
jdmrex91's Avatar
someone has to have some info on this.......bump
Old Aug 12, 2004 | 12:47 PM
jdmrex91's Avatar
anyone?
Old Aug 12, 2004 | 12:52 PM
EL Vap133's Avatar
The dust cover was crushed? What motor and tranny are you running? Have you tried adjusting the clutch cable if it's a cable tranny?
Old Aug 12, 2004 | 01:10 PM
fourthgenhatchB17's Avatar
Default Re: dust cap????? (EL Vap133)
If the mechanic inspected the pressure plate and said it was no good, then there is your problem. He probably saw worn/bent fingers or something. About the "dust cap", the only thing that could be is what u already stated, the plate that seals the dust/dirt out and mounts somewhat beneath the tranny. For the time being, until u find a good condition one, u can just leave the "dust cap" off all together. Was the pressure plate used when u got it? What year clutch disc did u use?
Old Aug 12, 2004 | 02:05 PM
jdmrex91's Avatar
Default Re: dust cap????? (fourthgenhatchB17)
i used both pressure plate and clutch disc from a 92 b18a
Old Aug 12, 2004 | 02:10 PM
kid-honda's Avatar
I think he means the viewing shield.
MPGIan
Apr 10, 2011 01:15 PM
knightsef-eg
Sep 17, 2008 12:07 PM
BlackKnight7
Mar 12, 2006 08:52 AM
John
Nov 29, 2001 07:29 PM
