Anyone done a a16z6 into crx si?
Old Aug 12, 2004 | 10:29 AM
white_shoes_09's Avatar
Default Anyone done a a16z6 into crx si?
If you've done it... What distrubutor did you use? I already did a search. Also trying to find the wiring diagrams or something that has the color codes for what each wire does. Any help appreciated.
Old Aug 12, 2004 | 10:39 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Anyone done a a16z6 into crx si? (white_shoes_09)
Depends on what ECU you use.
You can use your stock A6 distriubtor if you stick with your stock ECU and hook up a VAFC or something for VTEC activation.
If you go OBD1 and are planning to use a P28 for the Z6 then you need to use the Z6 distributor.
The reluctor wheel in the distributors have different teeth counts.
They send pulses to the ECU. Wrong teeth count = wwrong pulse count = wrong signal to ECU.
Old Aug 12, 2004 | 10:45 AM
Default Re: Anyone done a a16z6 into crx si? (4drEF)
Thanks man. My Si distributor wont hook up to it will it.
Old Aug 12, 2004 | 11:07 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white_shoes_09 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks man. My Si distributor wont hook up to it will it.</TD></TR></TABLE>
if you like doing things the ghetto way...........sure
C_R_X_V_T_E_C
Feb 18, 2007 06:15 PM
SiMateoAko
Aug 15, 2005 07:08 AM
civc 91
Mar 24, 2004 09:29 PM
bew-
Mar 8, 2004 04:35 PM
soundman
May 8, 2003 06:38 AM
