what tranny mount do I need?
Old Aug 12, 2004 | 08:51 AM
BigIslandBoi's Avatar
Default what tranny mount do I need?
setup: 90 DA with B18C1
Ive already searched.
Im about to pick up a JDM B16 cable tranny. What tranny mount will I need? Also I currently have the LS tranny, GSR axles, along with the stock GSR clutch setup. Will I need to also change my axles and clutch setup?
Old Aug 12, 2004 | 12:55 PM
VN712's Avatar
Default Re: what tranny mount do I need? (BigIslandBoi)
use the mount you are using from your ls. Reuse everything...it's just a tranny swap.
I am assuming that you are using a 91-92 ls tranny now b/c you are able to use the gsr clutch. Older tranny have less number spindle teeth if i remember correctly.
EDIT: MEANT TO SAY CLUTCH NOT TRANNY
Modified by B20ZLS at 4:13 AM 8/13/2004
Old Aug 12, 2004 | 04:22 PM
Default Re: what tranny mount do I need? (B20ZLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20ZLS &raquo;</TD></TR><TR><TD CLASS="quote">use the mount you are using from your ls. Reuse everything...it's just a tranny swap.
I am assuming that you are using a 91-92 ls tranny now b/c you are able to use the gsr tranny. Old tranny have less number spindle teeth if i remember correctly.</TD></TR></TABLE>
im sorry but im a little confused with your post. So I can use the GSR axles on the B16 tranny right? and also the GSR clutch setup?
Old Aug 12, 2004 | 07:11 PM
VN712's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigIslandBoi &raquo;</TD></TR><TR><TD CLASS="quote">
im sorry but im a little confused with your post. So I can use the GSR axles on the B16 tranny right? and also the GSR clutch setup?</TD></TR></TABLE>
YES...you can reuse your gsr axles.
YES....you can use your gsr clutch.
Old Aug 12, 2004 | 08:49 PM
3.504's Avatar
you need any DA axles gsr or LS... dc axles wont work, re-use the stock tranny mount.... thats it. if you get an 89-90 b16 tranny you need the 90-91 clutch, if its 91-92 b16 tranny, you need the 92-up clutch
Old Aug 13, 2004 | 09:27 AM
YES....you can use your gsr clutch.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">you need any DA axles gsr or LS... dc axles wont work, re-use the stock tranny mount.... thats it. if you get an 89-90 b16 tranny you need the 90-91 clutch, if its 91-92 b16 tranny, you need the 92-up clutch</TD></TR></TABLE>
alright lets clear things up here cause now I got two people giving me diff. results.
setup: 1990 Integra LS
1995 Integra GSR swap B18C1
1990 Integra cable LS tranny
1995 Integra GSR axles
1995 Integra GSR clutch
whos correct?
Old Aug 13, 2004 | 09:51 AM
VN712's Avatar
whos correct?</TD></TR></TABLE>
Dude...with your setup.... REUSE the axle you got on the DA now with the use of your DA intermediate. If you axles are mess up then you can use the 95 gsr axles....But, you HAVE TO get an 94+ teg intermediate shaft.
What year B16 cable are you getting? IF you are getting a 90-91 tranny..get a 90-91 bseries clutch. IF you are getting a 92-93 tranny..you CAN use your 95 gsr clutch.
Clear as a fish bowl now???
Old Aug 13, 2004 | 09:55 AM
VN712's Avatar
The reason why i said this is because you didn't clearify what year GSR is was. I though are you using the b17 (gsr) axles.
92-93 b series clutch is the same as the 94+ clutch. Same #of teeth, size, etc
Old Aug 13, 2004 | 10:01 AM
VN712's Avatar
Default Re: what tranny mount do I need? (3.504)
The reason why this dude say it won't work is b/c the intermediate shaft. 90-93 intermedite have a male/female end. The 94+ have a male/male end. For this reason, the using a 94+ axle on a 90-93 intermediate won't work. Getting the approperiate intermediate will make this axle setup work
Old Aug 13, 2004 | 10:04 AM
92-93 b series clutch is the same as the 94+ clutch. Same #of teeth, size, etc</TD></TR></TABLE>
alright mahalos for all your help! All i need to find out now is what year is this B16 that I plan on buying. Ill get back to you guys if i need help
hasaan
Transmission & Drivetrain
12
Sep 4, 2008 01:09 AM
jdmcivic1999
Sep 29, 2005 12:08 PM
riceburnah
Feb 1, 2005 05:00 PM
LSTEG96
Jul 24, 2004 12:00 PM
BigIslandBoi
May 6, 2004 06:51 PM
