93 Accord LX Transmission Problem
We have a 93 Accord LX (2 dr) automatic. The transmission seems to stick in first gear - mostly when cold but still even warmed up. Any idea on what could be the cause? Seems pretty good other wise.
I work at honda and i have seen this before. If u have over 120,000 miles on your car theres nothin u can do. Its just goin out on you so u have to rebuild it or get a trans for it or sell ur car while its still moving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xspamx486 »</TD></TR><TR><TD CLASS="quote">I work at honda and i have seen this before. If u have over 120,000 miles on your car theres nothin u can do. Its just goin out on you so u have to rebuild it or get a trans for it or sell ur car while its still moving. </TD></TR></TABLE>
I have 251,000 on my Accord and the auto tranny still shifts fine....
well ur one lukly son of gun u must not drive hard if it last that long the only time i see hondas with those miles there sittin in the back b/c they dont work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xspamx486 »</TD></TR><TR><TD CLASS="quote">well ur one lukly son of gun u must not drive hard if it last that long the only time i see hondas with those miles there sittin in the back b/c they dont work </TD></TR></TABLE>That's odd. The 4th generation automatic trans is bullet proof. I've replaced a few, but basically, 300K miles usually isn't a problem. We sure as hell didn't have several sitting out back because of transmission problems.
'91 Accord here, 247,400 miles so far on the original automatic tranny.
When i bought my car the transmission would get stuck in 2nd gear every now and then. My dad thought the tranny was trash but a friend of ours (honda technician) said it was whatever computer controlled the shifting (I'm guessing the TCM?) Ever since I've never had any problems with my transmission.
Change the fluid and add a can of lube guard for imports. When it is colder you want to left the car run for a few mins before you put it into gear.
There is something you can do to help solve the gear sticking problems....
Take the 2 shift solenoids off of the front of the transmission and clean them and the screens. Reinstall to trans and you should be good to go.
That trans is 100% electronic and when the car is cold, it will hold the gears longer to help th engine warm up.
If the trans has been properly maintained it should easily outlast the rest of the car (ie the car will turn to a rust pile before the engine or trans quits in that car). There is a dealer in my area that has seen quite a few 5th gen accords with 500K plus on original engine and trans and they are still being serviced.
The same cannot be said for the 6th gen transmissions as very few of them will make it past 200K and quite a few of them don't even make it to 100K
HI;
Actually I have a Honda accord and I think I'm having an electrical problem which I think is the alternator but the Main problem is the Transmission, when the Car is Cold the Transmission work Good , change and no check engine light and the D (drive) light is not flashing but after a 10 minutes driving the engine light come up then Drive light start flashing and transmission don't shift or shift ver Bad and if u continue driving it would automatically Move slowly very slow everytime u stop and going to move again , the speedometer don't work and I really don't know what's wrong with it , any Idea please help asap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ezdestination »</TD></TR><TR><TD CLASS="quote">HI;
Actually I have a Honda accord and I think I'm having an electrical problem which I think is the alternator but the Main problem is the Transmission, when the Car is Cold the Transmission work Good , change and no check engine light and the D (drive) light is not flashing but after a 10 minutes driving the engine light come up then Drive light start flashing and transmission don't shift or shift ver Bad and if u continue driving it would automatically Move slowly very slow everytime u stop and going to move again , the speedometer don't work and I really don't know what's wrong with it , any Idea please help asap</TD></TR></TABLE>
We could probably help you out but only if you use proper punctuation cause then we could see where your sentences end you know like this one doesnt seem to end it does not end very well I didnt type this correctly, yeah, it's messed up :D
Hello im having the same problem as ezdestination but i dont think that it has anything to do with my alternator at all. But my transmissions sounds amazing but drives very slow until it itz to tha speed that i want it and wen im goin up a hill it goes really slow if i was in a race with a turtle tha turtle would beat me going up a hill. And tha drive light flashes tha check enegine light **** on and everything.Can you please help me.
Then, retrieve the DTC and go from there.
