Power Window Stuck
I have the exact same problem with same vehicle except EX but no resolution either. I have replaced the windows regulator and the motor with used parts but still have the same problem. I have read about problems with dirty contacts in the switch. I'll try cleaning these until someone posts a fix.
Thanks for help in advance.
Guest
Posts: n/a
Check the rubber lining . sometimes a notch can catch the window... put some olive oil down the seal? , i tryed this once because my old accord had gotten a tint job by a moron that cut up the seals / but it was a manual window..
When you rip it apart , check and see if the tracking and the seals are intact... other than that i would just replace the f'n door / i hate windows
Milton90accord
Sep 5, 2003 09:00 AM
