any solutions to my no spark problem?
is there a ICM (ignition control module) fuse for OBD0 cars. my problem is, i have a 90' integra w/ an xsi in it and the ls harness, with a obd0>obd1 harness and injectors work but im getting no spark, i had no sauder kit or whatever so i just wired it w/ tape for now....but made sures its in good, but i had sum open wires, and i just read theres a icm fuse, so im gonna check that. if not then its probably my dizzy. how much do rotors and caps go for these days? should get a spark tester? i just need sum solutions, and ideas what i can get or use to help me find the problem. its late and i have no flashlight but im gonna check on that fuse tomorrow....so any ideas?
What them Carson boys aint helpin you out? Yes your car has an ICM and it's located inside the distributor. If you pop the cap off its the one that has all the wiring going into it. As for a cap and rotor. Probably $20-30. No sense replacing the icm if you are going to by a whole new distributor.
wood 1
12
Sep 24, 2006 01:37 PM
model x
Sep 13, 2002 12:51 PM
