does obd1 cat have 1 o2 sensor
Old Nov 30, 2001 | 01:19 PM
Rob Dizzle's Avatar
Default does obd1 cat have 1 o2 sensor
I have a 95 gsr. OBD1. I have the comptech header and catback exhaust.
I want to get a new high flow cat.
Me and dave at smsp cant figure out if the cat has just 1 whole for an o2 sensor or if there are 2....?
any guesses?
thanks
Old Nov 30, 2001 | 01:34 PM
b20b's Avatar
New User
Default Re: does obd1 cat have 1 o2 sensor (bob46802)
OBDI cars only have 1 o2 sensor. The sensor is not in the converter. The sensor is located in the down pipe before the converter.
Old Nov 30, 2001 | 01:46 PM
Rob Dizzle's Avatar
Default Re: does obd1 cat have 1 o2 sensor (b20b)
what downpipe are you talking about?
The cat bolts directly into the header
Old Nov 30, 2001 | 02:25 PM
jdmotorsports's Avatar
there's 2 parts to the header. the part thats directly connected to your engine is the collectors, from there its bolted to a y down pipe. on most obd-1 engines the o2 sensor is located in the bottom of the collector, or it coul be located on the down pipe between the cat and engine.
Old Nov 30, 2001 | 03:31 PM
nugget8000's Avatar
New User
Default Re: does obd1 cat have 1 o2 sensor (jdmotorsports)
I have a 94' GS-R and there is only one sensor and it is located on the front portion of the cat itself, not the collector or anywhere else on the header. I am absolutely posotive of this. HTH.
Old Nov 30, 2001 | 04:01 PM
Rob Dizzle's Avatar
Default Re: does obd1 cat have 1 o2 sensor (nugget8000)
thanks man, that is what i thought
I will jack up the car tonight to see what is going on
Old Dec 1, 2001 | 06:15 PM
HKxBlur's Avatar
and then there's the crazy GSR.. Like Nugget said, it's right before the cat body, but still considered 'on the cat'.. *Usually* it's like u said, on the 'downpipe' like sohc civics, or right before the collector..
JDM-Vic
Apr 29, 2010 05:04 PM
aimbot
Dec 6, 2007 08:20 PM
gtowni3
Apr 9, 2005 09:09 PM
DC2_Integra
Mar 19, 2003 04:39 PM
Rob Dizzle
Nov 30, 2001 10:46 PM
