less than 4 quarts of oil after draining, why??
Old Aug 11, 2004 | 11:49 PM
Xxcivic99xX's Avatar
Default less than 4 quarts of oil after draining, why??
Whenever I do my oil change, there is only about 3 quarts, maybe a lil bit less. I change my oil every 3000-4000 miles. I check my oil level 3 times a week and it is at the right level, between the upper and lower hole. I turn off the car and let it sit for 10-15 mins then check. my car isnt smoking so no burning and its not leaking?
anyone know why its like this?
This is also how my dads accord is too and it doesnt have leaks or burn any oil
Old Aug 12, 2004 | 03:47 AM
ryanstev's Avatar
Is your car on an incline?
Old Aug 12, 2004 | 06:35 AM
N2O's Avatar
N2O
Default Re: (ryanstev)
There is going to be some oil in the filter, and it is not uncommon for an engine to burn some oil between changes. It burns such a small amount at a time that you will not see any smoke.
Old Aug 12, 2004 | 06:20 PM
no its not on an incline, i lower it once the drain bolt and oil filter is off to make sure eveyrthing drains
Old Aug 12, 2004 | 10:27 PM
spaceman's Avatar
Default Re: (Xxcivic99xX)
do you know what a dipstick is? use it to measure how much oil you have or use...good luck
bopbop93030
May 13, 2008 04:30 PM
meangreenEG
17
Jul 28, 2007 11:36 AM
Puki
May 19, 2003 11:56 AM
94GsRacer
Sep 19, 2002 02:43 PM
dose
Aug 8, 2002 09:20 AM
