Lights dim when powering windows/ac/stereo.. normal?
Old Aug 11, 2004 | 10:20 PM
'99luder's Avatar
Default Lights dim when powering windows/ac/stereo.. normal?
I think I said it all in the title. Powering my windows up or down dims my headlights, same with a/c, sunroof, and stereo. Btw this is a 99 prelude.
Is this normal?
Old Aug 11, 2004 | 10:50 PM
dkny_stylez's Avatar
not normal, check your fuses
Old Aug 11, 2004 | 11:05 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: Lights dim when powering windows/ac/stereo.. normal? (prelude97)
mine does the same thing but its when i got my UR pullies put on.
Old Aug 12, 2004 | 05:31 AM
Behan's Avatar
Default Re: Lights dim when powering windows/ac/stereo.. normal? (raylude)
get a multimeter and check the output of your alternator. its should be about 13.7 to 14.0 volts
Old Aug 12, 2004 | 05:45 AM
britishlude's Avatar
Check out the voltage regulator as well, this distributes the right amount of power when devices are switched on.
Old Aug 12, 2004 | 05:52 AM
Sephro's Avatar
Default Re: Lights dim when powering windows/ac/stereo.. normal? (britishlude)
could also mean your battery is on it's way out.
Old Aug 12, 2004 | 07:54 AM
bboyprelude's Avatar
Default Re: Lights dim when powering windows/ac/stereo.. normal? (Sephro)
what about the lights dimming when you your car is off when you try to roll up the windows and or sun roof?
usually when i park i use this order turn off engine> sunroof> windows> lights.
Old Aug 12, 2004 | 08:07 AM
rjr162's Avatar
Default Re: Lights dim when powering windows/ac/stereo.. normal? (bboyprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboyprelude &raquo;</TD></TR><TR><TD CLASS="quote">what about the lights dimming when you your car is off when you try to roll up the windows and or sun roof?
usually when i park i use this order turn off engine&gt; sunroof&gt; windows&gt; lights.</TD></TR></TABLE>
they'll dim, because you're pulling extra power from the battery to roll up your windows and close the sunroof. Batteries have to product electricity via a chemical reaction. When you start to pull more amps (running the motors to roll the windows up, etc) the volts drop. The volts dropping are what's making your lights dim. As soon as you quit rolling up your window, the amp draw returns to the normal level, which inturn brings the volts back up so your lights are brighter again
Old Aug 12, 2004 | 08:55 AM
Behan's Avatar
Default Re: Lights dim when powering windows/ac/stereo.. normal? (rjr162)
you would be better off reversing that order. your putting undue stress on your batt. which will shorten the life.
DARS_C_C
Lighting
Jan 12, 2009 02:49 PM
R_A_Y_N_E
Feb 23, 2008 06:58 PM
Homesickelian
Aug 13, 2006 10:35 PM
steve_meyer
14
Sep 6, 2004 11:03 PM
cherns
Aug 10, 2003 01:08 PM
