Oil burning on my integra - i cant seem to figure it out! :(
Old Aug 11, 2004 | 09:04 PM
HybridGSR1's Avatar
Default Oil burning on my integra - i cant seem to figure it out! :(
My gsr when starting up has white smoke puffying out of the exhaust.. but after the car warms up everything seems ok.. no more smoke. The car is not driven hard .. but rather daily driven to work and back.. the car burns roughly 1/2 to 3/4 quart per week of oil... why is this happening.. i am really beginning to get frustrated as i can not determine the cause of this.
info:
-Good compression all the way across
-Leak down test done everything was good
-recently replaced valves (thought it was the valves that caused the oil burning)
-car only has 74xxx miles
-black stuff gets all over the back bumper from the exhaust
can anyone help me out with my situation.. hopefully help me pinpoint the problem before i just swap in a complete motor.
ps: could it be the piston rings? i thougt i wasnt becasue the car was showing good compression and leak down #s
Modified by HybridGSR1 at 6:59 AM 8/12/2004
Old Aug 11, 2004 | 09:22 PM
Bbasso's Avatar
Default Re: Oil burning on my integra - i cant seem to figure it out! :( (HybridGSR1)
Valve guides or seals Me thinks...
Old Aug 11, 2004 | 09:38 PM
TypeR15's Avatar
Default Re: Oil burning on my integra - i cant seem to figure it out! :( (Bbasso)
i acually have the same problem right now, im building the motor next month anyway but i have come to the conclusion its valve seals
Old Aug 11, 2004 | 11:21 PM
strepto's Avatar
Default Re: Oil burning on my integra - i cant seem to figure it out! :( (TypeR15)
Do a leakdown test. Its the only way to be sure. Could be valve seals, pistonrings... Only way to be sure.
Old Aug 11, 2004 | 11:35 PM
xmilanoredsix's Avatar
Default Re: Oil burning on my integra - i cant seem to figure it out! :( (strepto)
I always hear people talking about these tests....
Where would you reccomend going to get one of these done and how much does it usually run?
Old Aug 11, 2004 | 11:59 PM
92WhiteEG's Avatar
he already did a leak down test idiot
yu do the test your self.. is not hard to do at all
i really dont know.. if your compression is good, than your rings should be good.. and if your leak down test was good, then your valve seals should be good, so im not sure man
Old Aug 12, 2004 | 05:01 AM
703_Sleeper's Avatar
Use thicker oil. I think its 10-40w or something. That's what i did b/c i had the exact same problem. Haven't had it since and oil settings are fine.
Old Aug 12, 2004 | 05:29 AM
Splat's Avatar
Collector-o-Guns and Drinker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strepto &raquo;</TD></TR><TR><TD CLASS="quote">Do a leakdown test. Its the only way to be sure. Could be valve seals, pistonrings... Only way to be sure.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">-Leak down test done everything was good</TD></TR></TABLE>
Old Aug 12, 2004 | 04:39 PM
mugenracer's Avatar
It sounds very like valve stem seals...as when the car lies up over night oil leaks down through them and burns off once you start it up again in the morning. If the oil rings were done you'd be blowing plumes of smoke at high revs......
Old Aug 12, 2004 | 04:44 PM
Comp97GSR's Avatar
Default Re: (mugenracer)
I was under the assumption that a leak down test only checks the condition of the compression rings not the oil control rings (which would cause oil consumption). If this is not the case, please somebody set me straight.
Old Aug 12, 2004 | 04:59 PM
HybridGSR1's Avatar
Default Re: (Comp97GSR)
so the motor can have good compression, good leak down, but have a bad oil ring that can cause all this oil burning..
seems like i've found my problem?
wats next.. rebuild?
Old Aug 12, 2004 | 05:02 PM
Comp97GSR's Avatar
Default Re: (HybridGSR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">so the motor can have good compression, good leak down, but have a bad oil ring that can cause all this oil burning..
wats next.. rebuild?</TD></TR></TABLE>
I don't want to mislead you. I don't know and that is why I asked the question.
EDIT: White smoke on start up doesn't sound like oil burnoff though. If it is buring oil at start up, then most likely it is the valve seals or maybe the guides.
Old Aug 12, 2004 | 05:23 PM
Justin Klemgold's Avatar
If it only does it right after startup, it's your valve seals...while your car sits, oil drips down through the valve seals and into the combustion chamber...when you start it up, poof, it burns off...
If it were the rings, it'd do it under acceleration...
Old Aug 17, 2004 | 12:42 PM
gtowni3's Avatar
yup
TaffetaGSR00
Jan 2, 2011 05:43 PM
azzure180
Nov 24, 2009 10:35 AM
beatthisspeed69
Aug 15, 2008 10:25 AM
HybridGSR1
Aug 13, 2004 09:23 PM
bundy
Nov 19, 2002 09:04 PM
