i have a gsr 94 putting a new engine in it need to know whats faster or better
Old Aug 11, 2004 | 08:59 PM
thegsrfanatic's Avatar
Default i have a gsr 94 putting a new engine in it need to know whats faster or better
a 98-01 type R engine has 10,000 - 20,000 miles and its hp is 210, torque is 134 lbs-ft @ 7500 rpm, comp is 11,0:1 bore is 81mm stroker 87.2mm obd:2 redlines at 8900
or a 97-2000 Prelude Type-s same miles, hp is 223@7200rpm, Torque is 163lbs-ft@6500, same compression, bore:87mm Stroke is 90.7mm obd:2
the type R engine with everything is 4549 and the prelude is 3699.
so what one should i get thank you
Old Aug 11, 2004 | 09:01 PM
tsdenny's Avatar
Default Re: i have a gsr 94 putting a new engine in it need to know whats faster or better (thegsrfanatic)
i would go for the itr. engine is built to rev. internals are much better.
Old Aug 11, 2004 | 09:49 PM
batmang yO!
Guest
Posts: n/a
Default Re: i have a gsr 94 putting a new engine in it need to know whats faster or better (6thgensohcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6thgensohcvtec &raquo;</TD></TR><TR><TD CLASS="quote">i would go for the itr. engine is built to rev. internals are much better.</TD></TR></TABLE>
What he said!
Old Aug 11, 2004 | 10:30 PM
Gerbilo's Avatar
Default Re: i have a gsr 94 putting a new engine in it need to know whats faster or better (Beavis)
ITR motor, the H series outta the lude is extra weight up front that you don't need.
Old Aug 11, 2004 | 10:31 PM
aznsmtboy's Avatar
personally I go for the ITR engine, for the above mentioned reasons, and I'm sure the swap is alot easier too, do you need custom motor mounts to put a H series in the DC2? i don't know, I'd find that out.. In addition, what are your plans for the car? Are you planning on doing a drag setup, if so, then maybe the H series might be better as a platform, although B series have so much more aftermarket parts, you'll start off with alot more torque in the H series and some more HP according to the specs you posted. If you're thinking Autocross/Road Racing, then you need to stick with the B series, not only for the higher revs but to keep the car more nimble when you whip it around the twisties.
Old Aug 12, 2004 | 07:59 AM
rovigian's Avatar
You will be happier with the ITR in a teg. If this was a hatch I would prob say prelude engine.
Old Aug 12, 2004 | 09:00 AM
89preludesi's Avatar
the typer revs to 8400 not 8900
Old Aug 13, 2004 | 02:29 PM
Default Re: (89preludesi)
8900 go to totaljdm.com and find out about it your self
Old Aug 13, 2004 | 04:01 PM
Sack Master's Avatar
Default Re: (thegsrfanatic)
The last hype-r I drove didn't go to 8900. Must have been something wrong with it. The prelude motor is not a simple bolt in. It will be a bigger pain in the *** to do the swap. But they do run hard. I would pick the hype-r. They will probably run close to the same but the ITR motor will be much easier to do.
Old Aug 13, 2004 | 04:15 PM
Space Boy's Avatar
Default Re: (Sack Master)
I have a 94 gsr and had to replace the motor(due to oil consumption and age) and went with a pretty much B18C5 with around 11 compression. I have been nothing but impressed with this engine. The power is there even with the gsr gearing. The install wasn't an ordeal either. A few minor changes and it will work. Go for the B18C5 and you will be more than happy!
blacklsneedspower
Mar 25, 2009 02:14 PM
B18C5-EH2
Mar 21, 2005 03:56 PM
SMSP
Sep 21, 2004 05:27 PM
ragerized
May 20, 2004 12:32 PM
WAFFLES
37
Aug 6, 2003 03:41 PM
