Lsvtec 12.5:1 compression maybe 13.1 with 50shot?
Old Aug 11, 2004 | 08:45 PM
FlipSkater
Guest
Posts: n/a
Default Lsvtec 12.5:1 compression maybe 13.1 with 50shot?
fuilybuilt lsvtec would 50shot screw anything up would need at least 92 octance i only get 91 and i usally run 100,any comments?
EDIT:here the setup if you want it
b16 Dh-racing head Port and Poilsh
-ericking racing 68mm throttle body
-ib spec dual springs
-ferra valves
-ferra retainers
-ferra rocker arms
-jun 3 cams
-toda cam gears
-arp head bolts
-skunk 2 intake manifold
-j's racing intake with custom air ventalation to bumper
-smsp header
-370cc injectors
b18b1 block
-sleeved to 85mm
-ib spec superdupers 85mm
-ls crank
-ib spec rods
-arp rod bolts
-z10 griddle
-custom oil pan
-itr tranny
-hasports hrydo to cable convo
-hondata
Modified by FlipSkater at 10:53 PM 8/11/2004
Old Aug 11, 2004 | 09:52 PM
b16sedan's Avatar
Default Re: Lsvtec 12.5:1 compression maybe 13.1 with 50shot? (FlipSkater)
With only 92 octane I personally wouldn't spray on a 12.5:1 motor. Not on a 13:1 motor.
Old Aug 11, 2004 | 10:30 PM
FlipSkater
Guest
Posts: n/a
i could prolly go to 75 shot dry easily as long as its dry..wet dont like the idea of gas in my throttdle body and intake can result in fire...i need some comments guys!
Old Aug 11, 2004 | 10:37 PM
TURBOFTW's Avatar
anything over a 50shot i would go wet not dry....but thats just me
Old Aug 12, 2004 | 07:09 AM
FlipSkater
Guest
Posts: n/a
Default Re: Lsvtec 12.5:1 compression maybe 13.1 with 50shot? (h22dude)
why wet instead of dry?100octance should be fine retard 2 degrees
Old Aug 12, 2004 | 07:39 AM
TURBOFTW's Avatar
well with a 100 octane i guess it will be fine....didnt read that...
Old Aug 12, 2004 | 07:43 AM
FlipSkater
Guest
Posts: n/a
yah its going to be 100 octance and 2 degrees retard
Old Aug 16, 2004 | 01:13 PM
FlipSkater
Guest
Posts: n/a
i want some more comments before i decide
Old Aug 16, 2004 | 01:56 PM
vtec69's Avatar
i personally wouldnt spray a motor with that high of a compression
Old Aug 16, 2004 | 02:38 PM
PrecisionH23a's Avatar
11.0:1 is the highest CR I go with when running nitrous. Another thing you need to look at is how the Jun 3's will work in relation to the nitrous. As you know, with boost you are essentially blowing it out of the exhaust which leads me to believe you will do the same with the nitrous.
Old Aug 16, 2004 | 02:52 PM
FlipSkater
Guest
Posts: n/a
Default Re: Lsvtec 12.5:1 compression maybe 13.1 with 50shot? (PrecisionH23a)
i keep hearing cr doesnt matter just how it is built i dont see a porblem with 12.5:1 with sleeves and a dry 50shot?2degressed retard
Old Aug 16, 2004 | 03:23 PM
Stewie's Avatar
personally, I would not deal with the problems of unequal distribution of nitrous/fuel from using wet/dry shot on a motor that I spent good money on.
When it comes to having a reliable nitrous setup, I think dp is the only way to fly. Of course with dp, you can only go as low as an 80 shot.
Old Aug 16, 2004 | 03:30 PM
FlipSkater
Guest
Posts: n/a
Default Re: Lsvtec 12.5:1 compression maybe 13.1 with 50shot? (Stewie)
why direct port when i hear that i think engine boom! and you say an 80shot?i wouldent mind an dp setup but i just think kaboom
Old Aug 16, 2004 | 03:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlipSkater &raquo;</TD></TR><TR><TD CLASS="quote">why direct port when i hear that i think engine boom! </TD></TR></TABLE>
When i hear 12.5:1 cr w/ jun 3's and nitrous i think the same thing. The 100 octane will help out a bit, but to be safe you need to pull a good amount of timing.
I think you have a little more homework to do as far as nitrous goes... A dirct port will provide 1 jet into each runner combining both fuel and nitrous giving the same amounts of fuel/nitrous per cylinder.
Old Aug 16, 2004 | 03:51 PM
I just explained why.
Maybe you should read the site instead of us.
Old Aug 16, 2004 | 03:53 PM
FlipSkater
Guest
Posts: n/a
sry something werid happens alot a post before i do wont show up intill later on i have no clue why it does it sry thanks for the info
Old Aug 16, 2004 | 06:10 PM
ChaseIntegra's Avatar
I know a guy running a Direct Port nitrous setup sprayin 80 and that car hauls ***. But the only work he has done is to the head.
Old Aug 16, 2004 | 07:02 PM
FlipSkater
Guest
Posts: n/a
Default Re: Lsvtec 12.5:1 compression maybe 13.1 with 50shot? (ChaseIntegra)
ok so if i got high compression forged pistons what lenth should my rods be?does forged pistons screw up this all setup?
Old Aug 16, 2004 | 07:29 PM
FlipSkater
Guest
Posts: n/a
c16 gas help me out guys!!!!!
Old Aug 16, 2004 | 07:47 PM
shant's Avatar
get rid of the dry nitrous kit. use a direct port kit, especially if you want to run high compression. run the high octane gas. pull out more timing than you need, just remember to start safe on the safe side. you can add timing back in gradually when you are tuning the nitrous. if you run jun 3's your going to need to tune them for nitrous and compromise some of the all motor power, you have to tune out the overlap caused by the high duration cams so you don't spray the nitrous out the exhaust and waist it.
i don't think high compression and nitrous is a bad idea, just as long as you know what you are getting into. start Conservative and make sure its tuned.
Old Aug 16, 2004 | 07:52 PM
FlipSkater
Guest
Posts: n/a
Default Re: Lsvtec 12.5:1 compression maybe 13.1 with 50shot? (shant)
thanks very usefull info but i like to know you have to tune out the overlap ok if i spray and it goes out the exhaust?what cams would fix this but still give me enough power like jun 3
Old Aug 16, 2004 | 07:58 PM
shant's Avatar
im not saying dont use the jun 3's. you need to use adjustable cam gears and adjust the cam overlap to take advantage of the nitrous.
Old Aug 16, 2004 | 07:59 PM
FlipSkater
Guest
Posts: n/a
oh i c,wow your the guy ive been looking for whats your setup man i love your car and vids
Old Aug 16, 2004 | 08:07 PM
shant's Avatar
right now i have
b18a1 block
standard pr3 pistons.
ls rods,
arp rod bolts.
stock gsr head,
arp head studs,
ctr cams
nitrous directport 120shot from launch,
c16 race fuel
msd digital 6 ignition.
not sure when it will give up but thats what i have.
the civic is a 92 si hatch 1850 with me.
Old Aug 16, 2004 | 08:18 PM
FlipSkater
Guest
Posts: n/a
holy **** man your my rolemodel lol jk dam 12.2 no nitrous just with that nice but it is pretty lite but thats awsome
EDIT:i forgot, how many runs or miles you have on it
