Problems installing jdm front end
So im here trying to install m jdm front end and i cant put on the font bumper... I see that the old side marker metal things stick out am i supposed to cut those off to be able to install it?
and also how do i wire the healights? which is low beam and high beam here?
Modified by SiRII_Izzy at 9:27 PM 8/11/2004
Modified by SiRII_Izzy at 9:29 PM 8/11/2004
i didnt use a rad support for my JDM front end. it bolts right to where the USDM support would go.
also for the headlights, i BELIEVE it goes (based on your pic- right to left)
Highbeam, Ground (connect both high and low beam grounds to this wire), and Lowbeam.
twist em together and test before you make final connections, but im pretty sure thats how mine is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schwanginpt »</TD></TR><TR><TD CLASS="quote">i didnt use a rad support for my JDM front end. it bolts right to where the USDM support would go.
twist em together and test before you make final connections, but im pretty sure thats how mine is</TD></TR></TABLE>
bingo, match the colors together and put both grounds into 1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRII_Izzy »</TD></TR><TR><TD CLASS="quote">Also what about the headlights how am i supposed to mount them because im having troubling making it flush
if i get to lazy imma just take it to the body shop
which method are you using?? leaving the support on or not?? if the supports on, it might make fitting the headlights harder
i didnt use the bumper support, and my headlights bolted right up - no problems.
</TD></TR></TABLE>which method are you using?? leaving the support on or not?? if the supports on, it might make fitting the headlights harder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">bumper support does not interfere with the headlights</TD></TR></TABLE>
right. i was thinking he meant the lights "flush" to the bumper cover. not sure if the bumper support would push the JDM bumper out causing it to stick out from the headlights, making a gap/not "flush" to the headlights
Yeah im not using the bumper support hehe it wouldnt even get close to fitting... but now im like im going to die if i get into a accident hehehe...Oh well i think imma take it to a shop becuase i want this to be done perfect...
right. i was thinking he meant the lights "flush" to the bumper cover. not sure if the bumper support would push the JDM bumper out causing it to stick out from the headlights, making a gap/not "flush" to the headlights</TD></TR></TABLE>
i am using an HF support and mine fits fine
Do it yourself man, took me 3 hours to install the initial kit, then 14 hours the next two days to nit pick and line everything up perfect, takes time, might look like your going backwards at times whne **** start to go oout of wack then out of knowwhere they all line up
And this was on my friends car and I didnt really care lol, but I got $100
stockegsix
14
Feb 18, 2006 07:36 PM
