2004 Accord, Need help on replacing headlight bulbs
why is it so hard to the replace the bulbs in this car. its not my car but my friends and i was barely able to reach my hands in there to do any work. for these bulbs there's 3 screws that tightens the bulb adapter down. i was able to loosen the ones on the highbeams part and then u turn it counterclockwise and pull it out. but for the headlight bulbs i barely got space to put a screwdriver in there to loosen those screws. i only thing i saw was that to jack up the front end and go thru the wheel wall. why is it this hard to change the bulbs on this damn thing.
Guest
Posts: n/a
If it's like the 95 models the driver side headlight should be no problem... loosen the screws, pull the harness out, and replace the bulb. The passenger side should have a little resevoir b/t the battery and the headlight. Simply lift the resevoir out and set it aside and continue just like the driver side.
wekillyou
Sep 15, 2011 07:07 AM
