codes??? 6 - 9 - 3 on a crx with zc and zc ecu
im not sure how to read multiple codes, but those are the codes given and then they repeat them selves. Can anyone give me a hand. I broke my timing belt, put on a new one and these are the codes given, oh yeah, and its running on 3 cyls.
thanks
thanks
you need a new dizzy from what it sounds like, and if you snapped the timing belt at any RPM over 1200 you probably serevelry damage the piston or valves.. Or possibly a combination of both
code 6 is a CEL you shouldnt even have with an OBD0 setup.. and code 9 is cyl pos sensor,, which is on the exhaust cam.. I think this info is right. You can probably get all your anwsers are
http://www.thezcr.com
