few scratches on the surface of my block....will I be ok? can I file block?
Old Aug 11, 2004 | 06:05 PM
VTgringo's Avatar
Default few scratches on the surface of my block....will I be ok? can I file block?
I was scraping the old gasket off my block today when i noticed that it would get caught on a few scratches or small raised sections. Has anyone heard of filing these rough sections down with some fine grit sandpaper attached to a flat piece of wood? Any help or experience would be appreciated.
by the way....I just put this motor in, I really don't feel like removing it to get it milled a few .001. Both the surface of the head and the surface of the block are within spec and are not warped.
thanks guys
Old Aug 12, 2004 | 03:05 AM
VTgringo's Avatar
Default Re: few scratches on the surface of my block....will I be ok? can I file block? (VTgringo)
morning bump
Old Aug 12, 2004 | 04:01 AM
SiR Kid's Avatar
New User
If it's barely deep enough to feel, then just hose the headgasket in 2-3 coats of copper seal before installation.
NEVER sandpaper a block. Warp it, and you're f'd until you pull it to be milled.
Old Aug 12, 2004 | 06:29 AM
Filthy Focker!'s Avatar
Where are the scratches? On what part?
Like SiR Kid said, never file down a surface. Depending on the location, minor scratches do not pose a threat to the sealing ability of a gasket. So either you coat your gasket, or fill in the scratches.
fs
W O T
Feb 13, 2005 10:06 AM
c3p3r
Sep 7, 2003 08:27 PM
1sloaccord
Mar 14, 2003 07:17 AM
