Couln't start up my GSR, help!!!!
the other day i kinda wreck my car a little, when the crash start i quick shifted to neutral and damage to the front is the driver's axle popped into half losing the axle's bearing boots and the castle nut went lose and that about it...when i got my car towed home...and when i tried to turn it on...it cranking like distributor is dead or something, buzzing sounds,.....but no engine check light, or ****..just brake light and oil drifting **** are on.....wat can be the problem? my car still have a lot of batter power left ..so no battery here
1. Distributor dead? but how.. it looks all good,
2. Could it be my tranny, i shifted to neutral too slow when the axle got stuck and slow down but tranny gear is going at it speed? and messed up my tranny?
3. oil pan got no damage, no oil leaking either from tranny nor head...
4. could it be spark wires? or plugs, any possibility?
5. there is something under tranny mount and it has a wire connected from the battery RED...is that **** dead ....i htink it is....
will someone help me out with this.....thanx....
