need a good spot to disable the motor at night any ideas???
Old Aug 11, 2004 | 04:35 PM
slodel's Avatar
Default need a good spot to disable the motor at night any ideas???
i am moving to the cities for school and my car was alrady stolen once from the kid who owned it before me about 2 miles from where i am going to need some ideas to kill the motor at night thanks guys!!!! i know youll underdstand
Old Aug 11, 2004 | 05:51 PM
3.504's Avatar
Default Re: need a good spot to disable the motor at night any ideas??? (4doorhybrid)
are you talking about kill switches? put one on the fuel pump, and if you want, one for the starter relay and one maybe to the ignition primary.....
Old Aug 11, 2004 | 06:51 PM
.M.'s Avatar
.M.
Default Re: need a good spot to disable the motor at night any ideas??? (3.504)
take out ur spark plug wires
Old Aug 11, 2004 | 07:27 PM
boosted k20's Avatar
Default Re: need a good spot to disable the motor at night any ideas??? (JH4DC4)
You can have several kill switchs. U can put one on the fuel pump power line, one on the igntion, one on the clutch pedal activation line, and one on the starter. If ur really paranoid u can put all four of these kill switch's on your car. I also have one of those brake pedal clubs that u see advertised on TV. i think it's called the auto lock. i put it on my clutch pedal, so that way u can start the car and cant drive it. Im gonna add an ignition kill switch as well. i tried to put one on the fuel pump. i cut the power line and started up the car with the line cut to see if it would shut off. it idled for like 5 mins so i thought i cut the wrong line, so i just reconnected it and scratched that plan.
GPC91
Aug 17, 2012 05:23 PM
Mr. Prelude
May 21, 2011 07:27 PM
nateb22
17
May 1, 2009 07:47 PM
LSpimpTEC
Jul 14, 2003 07:37 PM
