I normally wouldnt post this here but who would know better than you guys
Old Aug 11, 2004 | 03:40 PM
137's Avatar
137
Default I normally wouldnt post this here but who would know better than you guys
How do I pre-determine a certain offset will clear my calipers before purchasing them?
The wheels in question are volk ce28n's
I am looking to get some wheels with these specs.
16x7 +35mm offset 5x114.3
I know I would be fine with the 42mm offset which everyone seems to run but I am trying to induce the webbed spoke look and I dont want to purchase wheels that wont fit over my calipers. Currently I am running a 5 lug ctr set up on my EM1 and I would appreciate any positive feedback, measuring techniques or so for the car.
I also will be purchasing spoon calipers as well when I pick the wheels up so I just want to make sure everything is going to work in harmony.
Old Aug 11, 2004 | 04:54 PM
chad's Avatar
Moderator
Default Re: I normally wouldnt post this here but who would know better than you guys (137)
i put 14inch ce28n's 25 offset on the poormans itr brake setup
Old Aug 11, 2004 | 05:20 PM
Cosworth's Avatar
For an ITR, 7" wheel will require at least +42mm offset to clear spoon calipers* (*disclaimer, most of the times it's +40mm due to the spoke design).
16x7" +35mm will definitely clear spoon calipers. You've got extra 5mm to clear the calipers with those wheels.
Old Aug 12, 2004 | 01:02 AM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 &raquo;</TD></TR><TR><TD CLASS="quote">How do I pre-determine a certain offset will clear my calipers before purchasing them?
you buy the wheel and test fit it
jk
jdmsta
Mar 16, 2009 12:36 PM
XX Boosted Si XX
Feb 8, 2008 09:54 PM
ZoRG
12
Oct 4, 2004 11:46 AM
1337 Si
Mar 27, 2004 11:55 AM
