how to change the tranny oil properly
Old Aug 11, 2004 | 03:15 PM
vidanator's Avatar
Default how to change the tranny oil properly
well i kind of know how to change the fluid, but i was just curious about making sure it is full because if i have jackstands under the car, the car is slanted and the fluid won't fill properly. but if i leave it flat i can't get to the filler plug, can someone help me please, thanks
Old Aug 11, 2004 | 03:16 PM
IN VTEC's Avatar
Default Re: how to change the tranny oil properly (vidanator)
Leave the front on the stands and jack up the rear.
Old Aug 11, 2004 | 03:18 PM
vidanator's Avatar
Default Re: how to change the tranny oil properly (IN VTEC)
hmm good enough for me, thanks
Old Aug 11, 2004 | 03:19 PM
purplegsr's Avatar
You could do 1 of 3 things:
1) buy another set of jack stands or jack the car up from the back, so that the rear tow hook is on the jack and the front is up on jack stands and the entire car is parallel to the ground
2) take the jackstands out, and carefully lower your car on your jack until it is holding it level
3) Put the tire back on, tighten the drain bolt and fill bolt, and put approximately 2.3 quarts of tranny fluid through the Vehicle Speed Sensor (VSS) hole.
Old Aug 12, 2004 | 04:20 AM
JimBlake's Avatar
Default Re: how to change the tranny oil properly (purplegsr)
Or...
4) Lower the car back down on it's wheels. Take off the intake air pipe & reach the fill hole from the top.
Old Aug 12, 2004 | 11:20 AM
GS-Rdriven's Avatar
Default Re: how to change the tranny oil properly (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Or...
4) Lower the car back down on it's wheels. Take off the intake air pipe & reach the fill hole from the top.</TD></TR></TABLE>
ur sig. is funny as **** ,
i know i didn't contribute to the thread sorry
martn53
Jan 4, 2010 01:34 AM
Sutterlude
Feb 26, 2008 10:01 AM
ReV LiMiT
Sep 18, 2004 10:49 AM
TrueUntilDeath.com
Aug 9, 2004 08:26 AM
cecknight
Oct 24, 2001 01:54 PM
