Who has a gsr engine in a 88-91 crx si...
Old Nov 30, 2001 | 10:32 AM
june's Avatar
Default Who has a gsr engine in a 88-91 crx si...
I just wanted to asked a few questions.. Did yall change the wiring to a gsr?? Cause i dont want to do all that bullshit of changing the wire harness.. Help me and my boy out on this swap.... My email is civicefhatchback@aol.com or aim at civicefhatchback....
Thanks June......
Old Nov 30, 2001 | 11:00 AM
internet ay's Avatar
Default Re: Who has a gsr engine in a 88-91 crx si... (civicefhatchback)
i beleive i saw that blown90hatch sells obd 0 to obd 1 wiring harness conversions for like 100 bucks or so(dont quote me) , i think what it is, is it is like a jumper harness deal, you use your stock harness and where the harness plugs into the ecu , his harness plugs into your harness and then you plug his harness into the ecu. i could be wrong though. you have to run the gsr ecu also. i found the post-https://honda-tech.com/zerothread?id=90627
[Modified by internet ay, 8:05 PM 11/30/2001]
Old Nov 30, 2001 | 05:08 PM
Blown90hatcH's Avatar
It is pretty easy. Keep the stock Si harness and plug my OBd0-OBD1 harness then. You will have to change some plug styles, but that is easy. Let me know if you need a harness.
Jason
Old Nov 30, 2001 | 06:49 PM
Tbone's Avatar
You can go with a pr3 or pwo jdm b16 ecu and distributor and keep the stock harness and add a few wires. My current setup is a pr4 ls integra ecu with a skunk vtec program and I have a vafc to actually activate the vtec and tune. But I'm personally going with one of blown90hatch's conversion harness's and from there I'll use a p72 gsr ecu with a hondata stage 4 set up. If you already have a obd1 ecu then without a doubt go the obd1 route. Plus if you contact him by tommorow he will knock 50. off his original price of 150.
clark81
Sep 5, 2010 11:52 AM
nello a.
Dec 24, 2008 12:20 AM
Jdmdctek
Jun 11, 2007 07:55 AM
oneforce
Apr 11, 2006 02:46 AM
VTEC5700rpm
Apr 29, 2001 03:47 PM
