Which throttle cable to use?
Old Aug 11, 2004 | 11:03 AM
Art701's Avatar
Default Which throttle cable to use (ITB's)?
I have a 1990 CRX Si, with a DOHC.
I have the old style TWM throttle linkage. Which throttle cable should I use? I currently have an ITR one and it is way too long. I basically need less play between the bracket (where it mounts) and the hook where the cable links to. TIA
I should have asked this before I (tried) to install it, because my cable was way too long. All that work for nothing, instead of ITB's I still have the P73 manifold with a stock TB. Any help is appreciated.
-Art
(posted in both the all-motor and tech forums)
Old Aug 11, 2004 | 03:23 PM
Art701's Avatar
Default Re: Which throttle cable to use (ITB's)? (Art701)
anyone?
Old Aug 11, 2004 | 04:19 PM
eda6's Avatar
Default Re: Which throttle cable to use (Art701)
I had that problem on my car (88 dx w/b16)
I cut about 2" out of my itr throttle cable.
I reconnected it with an electrical coupling and hit it with the solder gun.
Old Aug 11, 2004 | 04:40 PM
Art701's Avatar
Default Re: Which throttle cable to use (eda6 hb)
thanks for the response. i don't know if i want to have solder hold my throttle cable though. in the long run, it would not last.
Old Aug 11, 2004 | 04:49 PM
eda6's Avatar
The electrical coupling will if done right. i used a 10 ga spade connector. Cut the spade off.
The coupling is more than enough. Solder is extra insurance.
Old Aug 11, 2004 | 09:08 PM
Art701's Avatar
i see what you are saying. thanks for the input
Old Aug 12, 2004 | 08:52 AM
Art701's Avatar
SpoonEk253
May 20, 2006 11:42 AM
90jdmcrxdude
May 19, 2006 02:27 PM
Art701
Aug 15, 2004 05:41 PM
