Hazard Light Problem
Old Aug 11, 2004 | 07:15 AM
uvafroboy's Avatar
Default Hazard Light Problem
After taking the dash apart while changing out a cd player, my hazard lights do not work properly on my 1997 Accord EX upon reassembly. I can press the button in, and when I hold it the hazards work, but as soon as I release it, they cease working. It will not click on and off like it is supposed to. Any ideas if it is the actual button, or some relay or switch?
Old Aug 11, 2004 | 07:30 AM
Filthy Focker!'s Avatar
Default Re: Hazard Light Problem (uvafroboy)
If you touched it and it stopped working, then you need to remove it again and make sure it is installed right...
fs
Old Aug 11, 2004 | 08:16 AM
Heat's Avatar
Default Re: Hazard Light Problem (filthy_shovel)
Sounds like you messed up something when you took it out.
The plug on the back of it is kind of tricky, I messed mine up when I first got my '99 Accord and was putting in a CD changer (in October '98). The price for a new on back then was ~ $20. But yes, take it apart again and look at it carefully.
By the way, when you are removing it, a trick to help prevent scratching your dash is to wrap some masking tape around your flathead screwdriver's blade first.
ej1916
17
Jan 28, 2017 12:15 AM
drjay9051
Audio / Security / Video
May 20, 2008 05:16 AM
mkselecta
May 19, 2006 08:14 PM
DefendentOfHate
Jul 8, 2005 10:14 PM
XViEtBoiX
Aug 27, 2003 06:43 PM
