How do you convert ODB2 to ODB1 on an H23A Vtec (accord engine)
Old Aug 11, 2004 | 06:34 AM
yohan's Avatar
Default How do you convert ODB2 to ODB1 on an H23A Vtec (accord engine)
I've decided I want to get an H23A Vtec engine from the accord sir-t wagon .. from my research its the same h22a head, but a better balanced H23 crank with ~10:1 compression. Its also ODB2.
I'll be mating it up with my current H23 Transmission.
Since my car is ODB1 now (and i've checked, pre-wired for vtec). I'd like to keep it ODB1 ..
What do I need to change on the longblock to get it to ODB1 with working vtec ?
P13 ECU I assume ? ...
Old Aug 11, 2004 | 06:48 AM
uncle's Avatar
Default Re: How do you convert ODB2 to ODB1 on an H23A Vtec (yohan)
Ditch the resistor box, use your stock h23 dizzy (not h23a) and I think you will be good. Yes p13 ecu will be a good start.
Old Aug 11, 2004 | 07:17 AM
yohan's Avatar
How do i ditch the resister box / where is it ?
Old Aug 11, 2004 | 07:24 AM
H23 Power's Avatar
Default Re: (yohan)
I would get some OBD1 H22 injectors and keep the resistor box.
Old Aug 11, 2004 | 07:29 AM
uncle's Avatar
Default Re: (H23 Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 Power &raquo;</TD></TR><TR><TD CLASS="quote">I would get some OBD1 H22 injectors and keep the resistor box.</TD></TR></TABLE>
Why go to the trouble? It really doesn't make a difference.
96AccordCouper
Oct 3, 2013 08:01 PM
xotic_crx
May 26, 2007 09:18 AM
shavedH22AKCL
Sep 15, 2005 09:09 AM
4g4me
Jan 18, 2005 09:09 AM
BlueFang08
Apr 30, 2003 11:39 AM
