YOU! Turbo Charge My Type R!
Old Aug 11, 2004 | 12:33 AM
Haleiwa-Brando's Avatar
Default YOU! Turbo Charge My Type R!
Hello everyone in the world of Type R's. I have an assignment for you. In the very near future, I'll be turbo charging my Type R. I'm a bit unfamiliar with who is making kits or what out there, so I need your help on what you would recommend.
I would like to make a minimum of 350hp at the wheels. This is easily doable.
Here is a list of the parts that will be bolted on with the the turbo system:
Jun stage 3 cams
Rocket Motors dual valve springs
Rocket Motors titanium retainers
ST Corsa cam gears
Toda 1mm head gasket
Unorthodox pulley set
**ported and polished head
**match ported intake and exhaust manafolds
King Motorsports big bore throttle body
**sleeved block
MSD Ignition-full components
RC 650 injectors
AEM fuel rail
Spoon low temp thermostat
Spoon low temp fan switch
Fluidyne radiator
Spoon radiator hose kit
Spoon radiator cap
Maradyne dual radiator fan
**ECU tuning with Uberdata
All this **** is sitting in my house, collecting dust. I would like all of it in my car within the next two weeks. There is some stuff I'm sure I left out of the list, but I'm looking for the most effcient, complete turbo kit.
Your suggestions will be greatly appreciated. I'll post before and after dyno results when I get it all in.
Thanks a ton for all your help
Old Aug 11, 2004 | 12:38 AM
MiraiZ's Avatar
Default Re: YOU! Turbo Charge My Type R! (Haleiwa-Brando)
great! another turbo ITR post!
try asking the same question in the FI forum...they'll be more helpful there.
Old Aug 11, 2004 | 01:58 AM
swlabhot's Avatar
Jun Stage 3 cams in an FI motor?!?
Old Aug 11, 2004 | 03:36 AM
speedymon's Avatar
Default Re: YOU! Turbo Charge My Type R! (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">Jun Stage 3 cams in an FI motor?!? </TD></TR></TABLE>
Old Aug 11, 2004 | 03:45 AM
Misfit's Avatar
Default Re: YOU! Turbo Charge My Type R! (speedymon)
sounds like you flipped through a magazine and just picked parts because you heard they were cool.
Old Aug 11, 2004 | 04:24 AM
junkyard racer's Avatar
Default Re: YOU! Turbo Charge My Type R! (misfit)
http://www.homemadeturbo.com
(they are down till wed afternoon due to upgrades)
brautzen's Avatar
I got as far as that and stopped reading. Good luck with the turbo, y0!!
Old Aug 11, 2004 | 04:27 AM
Philly_NBP_R's Avatar
Default Re: YOU! Turbo Charge My Type R! (brautzen)
YOU! GO TO THE RIGHT FORUM.
(forced induction Einstein...)
Old Aug 11, 2004 | 04:28 AM
1GreyTeg's Avatar
Default Re: YOU! Turbo Charge My Type R! (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfit &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you flipped through a magazine and just picked parts because you heard they were cool. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brautzen &raquo;</TD></TR><TR><TD CLASS="quote">
I got as far as that and stopped reading. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">
try asking the same question in the FI forum...</TD></TR></TABLE>
Or pm ITR206.
Old Aug 11, 2004 | 05:16 AM
Kengs's Avatar
FWIW, Honda-Tech member Hypetune-Mark runs Toda Cs with his $$$$ turbo setup (IHI RX6 TCW77 turbo, Motec M4 PRO, HKS 1000cc injectors, OS Giken Pistons/Rods, OS Giken Twin Plate Clutch, stock B16A block)
http://www.hypertune.com.au/civic/
If you look here, you will find an ITR built by the tuning firm Cruise Power Craft (i think that's the right name); anyways, it has Jun pistons/rods AND Jun 2 cams
http://www.motor-land.net/mtld/dbview.cgi?uid=261
So it is possible? Yes, but you better be prepared to spend mega-bux
Old Aug 11, 2004 | 05:28 AM
Dr Pooface's Avatar
Default Re: YOU! Turbo Charge My Type R! (kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">So it is possible? Yes, but you better be prepared to spend mega-bux </TD></TR></TABLE>
Sure it's possible, but it's completely pointless. Why waste money on big cams when ITR cams have been proven to make over 600 whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Hello everyone in the world of Type R's. I have an assignment for you. In the very near future, I'll be turbo charging my Type R. I'm a bit unfamiliar with who is making kits or what out there, so I need your help on what you would recommend.
Jun stage 3 cams
ST Corsa cam gears
**sleeved block
RC 650 injectors
AEM fuel rail
Fluidyne radiator
Spoon radiator cap
Thanks a ton for all your help</TD></TR></TABLE>
Bold are parts, imo, that could be left stock on a 350 hp turbo ITR build.
I think you should search a lot, and lurk here and in the FI forum, before you ask others to give you all the answers.
Old Aug 11, 2004 | 06:45 AM
swlabhot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">If you look here, you will find an ITR built by the tuning firm Cruise Power Craft (i think that's the right name); anyways, it has Jun pistons/rods AND Jun 2 cams
Anythings possible. To lengthen your mods list maybe? To be different maybe? The cams in this setup are just a waste of time and money if you ask me...... I would spend my money more wisely elsewhere.
Old Aug 11, 2004 | 06:47 AM
GoodFella's Avatar
Unfortunate Clevland Sports Fan
Default Re: YOU! Turbo Charge My Type R! (Dr Pooface)
i think you would be better off in the long run going with lower compression forged pistons and either crower or eagle rods. maybe even an intank fuel pump. alot of those parts you dont really need you can sell and get an awesome manifold and a good sized downpipe and exhaust.
Old Aug 11, 2004 | 07:46 AM
Chris N's Avatar
Default Re: YOU! Turbo Charge My Type R! (GoodFella)
Reid? Is that you?
Chris - who thinks if it isn't Reid , then Reid should go help out with this project since he's j00 neighbor.
Old Aug 11, 2004 | 08:19 AM
Pompiuses's Avatar
No point changing valve springs and retainers........ Stock will do fine.
Old Aug 11, 2004 | 09:31 AM
done's Avatar
Default Re: YOU! Turbo Charge My Type R! (Pompiuses)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">No point changing valve springs and retainers........ Stock will do fine.</TD></TR></TABLE>
stock will not do.. stock will work only if you plan on reving to the stock redline.
Old Aug 11, 2004 | 09:34 AM
hYpE-R-29's Avatar
Jun stage 3 cams
ST Corsa cam gears
**sleeved block
RC 650 injectors
AEM fuel rail
Fluidyne radiator
Spoon radiator cap
PROVE IT....show us the pics neeeeeeeeewbieeeeee
Old Aug 11, 2004 | 09:41 AM
vtec.dc2's Avatar
Default Re: YOU! Turbo Charge My Type R! (Jordo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">
stock will not do.. stock will work only if you plan on reving to the stock redline.</TD></TR></TABLE>
with stage 3 cams and raising redline stock will not do, however, while turbocharged, you don't need to rev that high.. stock can go up to 9K
Old Aug 11, 2004 | 10:02 AM
xJ.SLOTHx's Avatar
youre sorta on the right track but you need to study up some more to understand how things work and what would be used and shouldnt be used when delving into the darkside...
Old Aug 11, 2004 | 10:24 AM
LoXy's Avatar
Default Re: YOU! Turbo Charge My Type R! (ian)
GOGOGOGO mate tell us ur results once u got everything done i cant wait
Old Aug 11, 2004 | 10:43 AM
Tweakmeister's Avatar
Default Re: YOU! Turbo Charge My Type R! (LoXy)
Here's my advice:
Learn to **** gold bricks.
Old Aug 11, 2004 | 10:51 AM
Default Re: YOU! Turbo Charge My Type R! (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">Here's my advice:
Learn to **** gold bricks.</TD></TR></TABLE>
good advice.
(I still havn't figured that one out yet )
Old Aug 11, 2004 | 12:04 PM
GoodFella's Avatar
Default Re: YOU! Turbo Charge My Type R! (Philly_NBP_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">
good advice.
(I still havn't figured that one out yet )</TD></TR></TABLE>
me either and i forgot to give my money tree some water and it dried up and died!
Old Aug 11, 2004 | 12:06 PM
Dave-ROR's Avatar
send me your car and $20,000 and I'll get 351whp for you. Then I'll pocket the extra.
Old Aug 11, 2004 | 12:58 PM
Pompiuses's Avatar
To give you an idea of what's needed when turboing an R you might want to look at this link: http://kvien.no/integra/boost/budsjett.html
Some of the parts might be overkill for a 350whp setup, but you get the general idea.
