Hesitant Type R
Old Aug 10, 2004 | 11:46 PM
McAuslane325's Avatar
Default Hesitant Type R
Ladies and Gents
Have got a '99 Type R, which when on form is an automotive joy to drive. However, until the wonders of VTEC kick in, acceleration is not smooth is somewhat hesitant and occassionally prone to pre-detonation. The car has always been main dealer serviced, and run on Optimax. She has done approx 63k miles and has just had a main service. Have queried Honda a number of times about the issues, but they report all seems to be fine. Have just changed on advice to running on Super-Plus Unleaded, which seems to have made an improvement. Any and all advice gratefully received
cheers...Bruce
Old Aug 11, 2004 | 12:29 AM
kevinm1981's Avatar
Default Re: Hesitant Type R (McAuslane325)
a 99 accord euro type R?
Old Aug 11, 2004 | 03:28 AM
kniob's Avatar
Default Re: Hesitant Type R (kevinm1981)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinm1981 &raquo;</TD></TR><TR><TD CLASS="quote">a 99 accord euro type R?</TD></TR></TABLE>
it's just the "Euro R", not 'euro type R'.
Old Aug 11, 2004 | 04:36 AM
iakona's Avatar
have you ever had a proper fuel injection system cleaning?
Old Aug 11, 2004 | 04:39 AM
Turbowa's Avatar
The higher octain fuel will help. You may want to check you timing with a timing light. You could be pulling advanced timing and not even know it. If I remember correctly you can play around with your timing a little by moving the dist. sub assy., but use a timing light to set the timing.
Old Aug 11, 2004 | 07:17 AM
Default Re: (iakona)
Have put through fuel system cleaner that just gets added to fuel tank. Is this different from what you're terming a proper injection clean?
Old Aug 11, 2004 | 07:18 AM
Default Re: Hesitant Type R (Turbowa)
Thanks for advice regarding timing, may invest in proper rolling-road set up
Old Aug 11, 2004 | 07:48 AM
earthworm's Avatar
What in the world is a rolling-road ?? A dynamometer ??
The use of a timing light is a good idea .. I have not done this in years, doubt if my timing light still functions.
Old Aug 11, 2004 | 12:01 PM
iakona's Avatar
yes, a rolling road is a dyno.
and timing on OBD II H22s cannot be adjusted at the distributor like OBD I H22s.
raviee
Acura TL, RL & ZDX
Mar 27, 2008 11:03 AM
Mr.DC2TurBo
Feb 12, 2005 07:59 AM
DC5AM
10
Jan 23, 2005 09:23 AM
BlackAckeR
Jul 12, 2001 03:24 PM
