89-91 SI transmission work with 88 engine?
Old Aug 10, 2004 | 10:10 PM
LASSEN768's Avatar
Default 89-91 SI transmission work with 88 engine?
I know that the 1988 crx transmissions have 21 splines and the 89-91 have 20 splines. I was wondering if I can put in a 89-91 si transmission if I get the 89-91 clutch on a 1988 crx. I've searched but haven't found anything that would answer my question directly...
would a 89-91 clutch even fit on a 88 engine? 1988 si transmissions the only option? Thanks in advance
1988 crx dx 5 speed
Old Aug 10, 2004 | 10:27 PM
mmuller's Avatar
Mad Scientist
Default Re: 89-91 SI transmission work with 88 engine? (LASSEN768)
im pretty sure that the tranny will bolt in fine; as far as the splines, just get the matching clutch disk.
Old Aug 10, 2004 | 10:41 PM
turbohondask's Avatar
Default Re: 89-91 SI transmission work with 88 engine? (mmuller)
i think it is also bigger, it might need the flywheel and clutch set
Old Aug 10, 2004 | 10:42 PM
mmuller's Avatar
Mad Scientist
Default Re: 89-91 SI transmission work with 88 engine? (turbohondask)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohondask &raquo;</TD></TR><TR><TD CLASS="quote">i think it is also bigger, it might need the flywheel and clutch set</TD></TR></TABLE>
cool, i was wondering that
Old Aug 10, 2004 | 10:46 PM
LASSEN768's Avatar
awesome...I was thinking I would have to need a matching clutch disk. I just wanted to get confirmation. I would then need to get matching flywheel for the clutch disk, right?
2003TTacoma
15
Aug 3, 2012 12:34 PM
aj_zo
Jun 15, 2006 08:04 AM
D15BREX
Jun 2, 2005 09:27 AM
dstudent
Nov 2, 2004 09:06 AM
vtec_head
Oct 21, 2003 05:35 PM
