Anyone have a Kaaz LSD
Old Aug 10, 2004 | 07:57 PM
krazie1's Avatar
BANNED
Default Anyone have a Kaaz LSD
To there JDM cable transmission in this section
wondering can't get the VSS to stay in the right height or to stay lower enough to actually touch the diff.
could it be the LSD is to big works with the axles and turns
trying to get this sucker running this weekend
HELP!
Old Aug 10, 2004 | 08:45 PM
krazie1's Avatar
BANNED
Default Re: Anyone have a Kaaz LSD (krazie1)
No one huh
Old Aug 10, 2004 | 09:43 PM
goforbroke's Avatar
MEAT PATTY
I have a clutch type lsd in my car but to tell you the truth I"m not sure if its a Kaaz or whatever, But I know its a clutch type like Kaaz. In regards to the speedo not sitting right. If the differential wasn't sitten correctly inside the housing it would be making alot of noise. Is the tranny making any noise, or did you even get it running yet?
Old Aug 11, 2004 | 09:02 AM
azulito's Avatar
Default Re: Anyone have a Kaaz LSD (goforbroke)
I have a KAAZ LSD in my Si tranny. The speedo cable gear thingy you need comes only from KAAZ, it is custom. If you are using a stock one it wont work. Hope that helps. I had to order one and it was 70 bucks I think...
Old Aug 11, 2004 | 02:19 PM
krazie1's Avatar
BANNED
Default Re: Anyone have a Kaaz LSD (azulito)
Thank you guys I was just told this too
by a known racer in these fourms
I will hit someone up for one
revikan
Transmission & Drivetrain
Mar 12, 2018 05:19 PM
spec_ed
Sep 30, 2004 10:07 AM
EF'n
Sep 9, 2004 07:37 PM
chambersef8
Apr 1, 2004 06:03 PM
CivicSiR7
11
Feb 18, 2002 10:10 AM
