I need some information about my swap?
I recently invested in a B18(ls integra) engine & trans, i wanna put it into my 1995 civic sedan. I was wondering what type of mounts i need, which axles to use, will to\he wiring harass be the same, which ecu to use? Please help, i'm new in the game of honda engine swaps.
check out http://www.hasport.com for mounts and axles or try http://www.optionsauto.com for mounts. the hasport mounts are expensive but ive heard theyre worth it. i have hasport axles and enjo mounts from optionsauto.com but my swap isnt done so i cant tell you how good it is. hasport will also have ECU harnesses for you. if you got a complete engine swap then i would start off by using the ecu that it came with unless theres something specific you want.
240sxDrift
Aug 3, 2005 07:55 AM
Maddox
Jul 27, 2005 08:47 AM
