Guess what today is...
The one year anniversary with my type R
I picked her up on 11-30-2000 with 8.9 miles. http://www.imagestation.com/album/?id=4293264787
First off... my favorite number.
Over the past 365 days I have driven my ITR ~23,500 miles and have been to 4 track events (one at Lowe’s Motor Speedway, 2 at VIR Long, 1 at VIR North).
I have gotten as high as 34 mpg (413 miles on that tank) and a low as 9 mpg (on track).
First oil change at ~2,400 miles
Tested rev-limiter at ~4,250 miles
Oil changes:
8 changes = ~2,900 miles between changes
Transmission fluid changes:
5 changes = ~4,700 miles between changes
Tires:
First set lasted 15,330 miles
Second set (RE010’s) will die next weekend at VIR (~24,500 miles total)
Third set will be Falken Azenis (205/50/15)
Modifications:
Honda parts:
-4 into 1 header
-hanger for said header
-heat shield for said header
-parking brake cover with rear bracket http://www.imagestation.com/album/?id=4292517121
-23mm rear bar (thanks IPS)
-clock blocker (thanks IPS)
-shifter boot with red stiching (thanks IPS)
-Access Pedal covers http://www.imagestation.com/album/?id=4292517129
-Access rear strut bar http://www.imagestation.com/album/?id=4292517111
-Access rear window film (type R)
-rear wiper removal plug (thanks Mike K)
Other modifications:
-Spoon drain plugs http://www.imagestation.com/album/?id=4292566341
-shifter bushings
-motor mount inserts
-2.5" SMPS Carsound cat
-Autozone front brake rotors
-Hawk Blue brake pads
-ATE super Blue brake fluid
-antenna switch (to lower antenna when a CD is playing)
-removal of power door locks using RS door pieces
-use of a sunroof switch to operate the power door locks
-80% install of cruise control off of a GSR
Various pics: http://www.imagestation.com/album/?id=4293249869
I will bake a cake and sing to my baby this evening.
William
-who loves his Type R
Oil changes:
Tires:
Modifications:
Honda parts:
-4 into 1 header
-shifter bushings
William
Spelling...
Guess what todayIS.
Fyi.. the rear strut bar cover on the pass. side has been fixed.
The template looked strange... so I cut the cover the same as the template.
Will
-who works...sometimes
Guess what todayIS.
Will
Spelling...
Guess what todayIS.
Guess what todayIS.
congrats on your anniversary....hmmm mine is almost 3 and a half years and I only have 28K on mine...must drive more, too bad I have no where to drive to
I had mine for a year last week, 12500 miles. 4 oil changes, first change at 3100 miles, first touch o VTEC(just barely)at around 200 miles, first redline at 960 miles after dealer told me I baby the car too much. Tires still really good cond., avg. of 240 miles to 9 gallons of gas, no burnouts, no chirping, never hit revlimiter. Only abuse was a couple of harsh downshifts and a near mishift(dumped the clutch before redline). Emblems were recently jacked. Car bone stock. Hope my R is in good health.
too bad i have no where to drive to too
Drinker
