new rotors for new pads?
you can use the same rotors as long as theyre not too thin. But make sure you have them turned before you swap the pads on.
Warren
Even that is overkill. Just be sensable on how you bed them in. If the rotors are grooved, then it's going to take a while to match up. If they're in good shape then turning is overkill.
Using 50 grit sandpaper is to break down friction material film transfer from the previous set of pads. If you have any grooving on your rotors, you should turn them, and ensure that you are within 15% of spec. If not, then get new rotors. As you turn a rotor down, you are reducing its mass, and thus ability to absorb thermal energy....it will be more prone to warping and cracking.
Here is what I don't want: Someone who turns their rotors and it is right at spec...then installs our pads...achieves better stopping power because of our pads...thus drives the car harders and brakes harder...warped his rotors...blames the pads for the warped rotors. This type of logic = irresponsible bullshit.
Trust me...I've heard all the stories and claims...so nothing would surprise me.
As an aside, the phenomenon of rotor warpage is 100% unrelated to the type of pad compound you are using.
Andie
Andie
99_SH
15
Mar 5, 2003 07:06 PM
